Subwoofer/Amp Installation
Can anyone tell me what type of connector/harness is required to hook up an amp/subwoofers to my 2000 Blazer with a stock radio? I was planning on getting an amp wiring kit from Best Buy but I'm not sure about the connections to the radio.
Thanks |
There is no actual harness to tie in an amp and woofers to ur stock system but there is however a lil box tht u can pick up from just bout any electronic store or wal-mart tht converts speaker wire to rca cables. It is spliced into ur rear speakers and provides RCA jacks for ur amp only problem is tht it doesn't filter the sound. basically u get highs mids and lows all going into ur woofer. but ur in luck cuz they also sell an inline filter for tht set up
ask the guy at best buy bout it. it's out there I know cuz I have used it before. can't remember where I bought though
Excatly thanx Bravado
alright thanks that helped out a lot.. ill get back on in a few days after i try and hook them up to see if i have any other questions.. thanks though
Don't forget to hook up the remote wire like I did...it's annoying, especially after you put the dash back together...lol
I did want to get behind my dash to hook up the line level converter, so while thinking up a good solution I remembered by back speakers were blown and I can live without them so I cut into the rubber peice carrying wires from the body into the door, pulled out the two speaker wires, spliced onto them with more speaker wires and some crimpers, and ran the lenth to the back where the subs are. Mounted the conveter to the box and all was well, im running two kenwood tens and a rockford fosgate amp
| All times are GMT -5. The time now is 07:10 AM. |
