subwoofer problem
Old Mar 27, 2010 | 09:55 PM
bumpinBEATS95's Avatar
bumpinBEATS95 is on a distinguished road
Default subwoofer problem
when my RCAs are hooked up to my amp, my subs start hitting without any volume turned up, im completely stumped. any help?
i have a pioneer avh-p5700dvd, a memphis 100watt amp, and two kicker cvr12s, by the way
Old Mar 27, 2010 | 10:51 PM
BlazerGuy2001's Avatar
check the settings on the amp and make sure they are all at the midpoint? thats about all i can think of....
Old Mar 27, 2010 | 11:51 PM
wlorton's Avatar
Did someone play crank the gain?
Old Mar 27, 2010 | 11:54 PM
lol thats what it sounds like....boomboomboom
Old Mar 28, 2010 | 04:03 AM
MTopper's Avatar
i had a similar problem but not a continual bump... my rcas got cut somewhere between HU and amp under the carpeting and would send a burp through my sub when i turned the radio on or off.. check your RCAs all the way through to make sure its not grounding out to the truck
Old Mar 28, 2010 | 05:26 AM
its not my RCAs, cuz everything was working fine with my kenwood a few days ago, and Ive checked all my lines too
would a looped ground cause this?
Old Mar 28, 2010 | 08:55 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
I hate to call you out, but this is terrible advice. There are PROPER ways to set all of those adjustments.
My recommendation is to get a new set of RCAs. They are usually the root of this common issue.
http://www.knukonceptz.com/productMa...y=RCA%20Cables
Old Mar 28, 2010 | 10:53 AM
lol i didn't mean set them at the midpoint permanently, but do it just to see if that fixes the problem and get it tuned from there...
Old Mar 28, 2010 | 09:54 PM
MTopper's Avatar
If you think your RCAs are still ok, try plugging in your old kenwood. and i would agree with Bob, better RCAs usually fix most buzzing/burps
Old Mar 28, 2010 | 10:36 PM
zedartwo's Avatar
Really just sounds like your gain is cranked!
