RE: A sweet upgrade
ok ok slow down simple langue please, enginner language(simple)
just give me a few amps and prices if you want to please o so no matter how high i putthese subs n my current amp they wont be damaged?? ok no offesense. i can wire up the most complexe amp setup an d hide wires like they were placed by the factory, but i can never figure out the amp configuration and you guys talk like at least to me like you knoa all, like i said before no offense here is old speakers http://www.hifisoundconnection.com/S...id/0/SFV/30046 |
RE: A sweet upgrade
ORIGINAL: Tippman7641 lmao this is the current amp i will use for the time vbeing http://www.hifisoundconnection.com/S...id/0/SFV/30046 |
RE: A sweet upgrade
hah will you guys finnly respect my system once i get the proper amps with these speakers? lol
RE: A sweet upgrade
with 2 dual 6ohm subs, you can either wire them for 1.5ohms or 6ohms. Each sub is 300RMS so you need to find an amp that will either pump out a clean 600RMS at 1ohm or at 6ohm. Since 99.9% of amps will not have a rating for 6ohm, a 1ohm stable amp will be much easier and cheaper to find.
RE: A sweet upgrade
could you recomend some please? oh and how should i wire wire my current amp for right now?(yes i now they are underpowered
RE: A sweet upgrade
RE: A sweet upgrade
thats so expensive for my current budget i could cry\\
id only need one right, just need to bridge right? thanks btw |
RE: A sweet upgrade
well, you dont have to buy it from the manufacturer (both are the same company, likely the same amp internally) i was looking for ebay links for them and you can get the orion for $215...
what is your budget? its difficult to suggest amps without having an approximate price range on a MONO amp, there is nothing to bridge. one [-] speaker output and one [+] speaker output... |
RE: A sweet upgrade
i wann say 160 but i can save for a few eeks to like 300 MABE
o and should i do that for my current amp?? just for now? |
RE: A sweet upgrade
PERFECT!
600rms for $170.... it would be best to wait for some more input from some of the more experienced guys. im not sure on the quality of Directed amps... a good place to look is www.onlinecarstereo.com on the left column, select MONO AMPS and look through them, you want to look for an amp that puts out 600+ rms @ 1ohm. |
