System questions ?!?!?!
How many factory speakers are in my truck and what size are they ?
What is ur opinion on two kicker 12" L5's 2400w max 1200w rms in a ported box powered by a hi phonics amp 1200w ? Are buying tweeters and a capacitor worth it or just a waist of money ? Thanks in advamce any advice would be greatly apprechiated :) |
RE: System questions ?!?!?!
In my Blazer (95 4 door LT) there are a total of 6 speakers. 4 6" speakers in each door and 2 tweeters on the dash (not sure on the size of those). As soon as I got my Blazer I took out the POS Delco deck and replaced it with a Clarion (which is now an Alpine) deck, and replaced all the speakers (except the dash tweeters) with an Infinity component setup, so I have replaced the Delco door speakers, and drilled 1" holes (the size of the tweeters) at ear level in the door panels, and what a WORLD of difference. The speakers more then easily keep up with my subs, and it sounds so clear and natural, so yes tweeters are for sure worth it because you can create a whole new soundstage. It's a good idea to move the tweeters around and play some music and find the best location for them before you do any drilling. As far as caps go, it's a hugely debated subject, but I think it's a good idea to use one if your pushing more then 800 watts RMS, but it also depends on the strength of your battery/alternator.
Thanks my friend said i should get the capacitor to help take strain off the battery/alternator so i might ... thanks for all the help :)
https://blazerforum.com/m_83055/tm.htm for specs and other good info
And yes, a cap is a waste of money, tweeters, its up to you. |
im pretty sure they're 6 1/2" speakers and a 3/4" tweeter in a plate in the dash......buy a component set and tweeters and crossovers come with it, ditch the cap and dash speakers and get a lil 50x2 2 channel amp.
OH and if your UN AMPED speakers can keep up with your subs.........YOUR NOT LOUD ENOUGH [8D] |
Okay thanks so thats wat i thought capacitor is a waist of money so ill just go wit the yellow top battery.
Thanks for all your help. |
OH and if your UN AMPED speakers can keep up with your subs.........YOUR NOT LOUD ENOUGH |
lol
