toggle switches
I have some LED's in my blazer. I want them to be able to turn on when the dome light goes on and i want to be able to turn them on at anytime even if the dome light is off. I found a switch that i think will work but is says its for 125VAC. Will this work for my blazer or not. If it does would this work how on want it to. http://order.waytekwire.com/CGI-BIN/...FD5072+M37+ENG
RE: toggle switches
your link doesnt work. Sounds like you will have to wire up a complicated array of relays.
RE: toggle switches
here is the website http://www.waytekwire.com/index.htm the item number for the switch is 44207.
RE: toggle switches
so can anyone help me. will this work or will i still need to hook up some relays
RE: toggle switches
anyone????
RE: toggle switches
just have then turned on by 2 relays one realy turns on with the dome lights and one with a switch
RE: toggle switches
You could use one relay with a double trigger. Some diodes can be used as to not back feed into the dome light circuit. A great resource for 12v electrical setups is the12volt.com.
RE: toggle switches
since it is an on-off-on switch with 5 terminal would i be able to wire it so i could leave it fliped on on way so it will go on with the dome and fliped the other way to turn it on manually. also will this switch work for 12volt.
RE: toggle switches
If it is a SPDT or DPDT switch, then yeah, you could supply +12V constant to one 'throw' of the switch and then have the dome light circuit supply +12V to the other 'throw' of the switch.
RE: toggle switches
ok thanks
| All times are GMT -5. The time now is 03:55 AM. |
