"True" 4 AWG help?
1 Attachment(s)
Well to keep the story short... I got 25 feet of red and 25 feet of black 4 awg from eBay. It arrived today and has 4 awg Bullz Audio on the actual cable. I go to look at the end of the cable and it doesn't look anywhere near 4 awg. Can I get a second opinion on this? What does everybody think? Should I complain it isn't 4 awg and try to get my money back?
Picture: https://blazerforum.com/forum/attach...ine=1356048884 http://i280.photobucket.com/albums/k...ps421b30a1.jpg |
That is not true 4 AWG wire. How much did you pay for it? I've gotten quite skeptical of most wire out on the market. If it's not Kicker Hyperflex, Streetwires, or KnuKonceptz I won't recommend it. I recommend Knu alot because it tends to run oversize and they have about the cheapest prices that can be had for the wire as well.
Originally Posted by altoncustomtech
(Post 557628)
Bullz audio is slightly undersized wire and it is also CCA, so keep that in mind.
Wire is my thing, since I do a lot of car audio. 34 bucks isn't bad for 50ft though. |
I agree. For the price you paid you sure didn't get ripped off.
What are you planning to run it on? The fact that it's a little under sized may not even be a participating factor. The Knukonceptz 4AWG KCA wire (also CCA) is $95 a foot. CCA doesn't bother me as long as it's being used for it's intended purpose and so within it's limitations. |
(Post 557638)
What are you planning to run it on? The fact that it's a little under sized may not even be a participating factor. The Knukonceptz 4AWG KCA wire (also CCA) is $95 a foot. CCA doesn't bother me as long as it's being used for it's intended purpose and so within it's limitations. But I need to upgrade my big 3 wire because I found an ad244 alt I need to install to support my aux lights and sound system. I'm afraid the bullz audio 4 awg wire is the same gauge (8 awg) that the system has right now. I know Knukonceptz 4 awg runs a little big which is a plus. I was going to get 20 feet of Knu's 4 awg for the big 3. That should be enough. I don't think I can get away with using bullz audio 4 awg (more like 8 awg) for the big 3. So what should I do with it if I can't return it? |
I like welding cable, its not pretty colored but the insulation is better than stereo shop wire. The sizing is also more regulated.
My biggest issue with more CCA is the it's lack of corrosion resistance. It will corrode much faster than OFC. Any wires under the hood I typically search for silver tinned wire. Lasts way longer. There's a few companies making silver tinned CCA.
DIYMA 1/0 Gauge CCA - 50ft - Cables and Wires That's one of them. I'll be laying down 4-5 runs of that when I get my HO alt. They had a sale a while back, 50% off, so I picked up two spools :) Under hood I also crimp and solder my connections. Just throwing stuff out there. |
Originally Posted by tibby
(Post 557642)
If it was $95 a FOOT it better be gold plated haha. :P
Originally Posted by neo71665
(Post 557645)
another thing I left out, is you can use some no ox to help prevent corrosion. |
Originally Posted by armykyle1
(Post 557654)
What is the amperage of it? if you're not happy with the wire, double up the runs. Save money.
(Post 557654)
I don't know about that. Having used welding cable and lots of car audio wire. Maybe cheaper wires, yes. But stinger, kicker, RF and other brands no.
| All times are GMT -5. The time now is 06:15 AM. |
