trying to find room
dont think you will find room for them. If you could find a spot you might have a problem with cooling since it would be tight. Just a bit of advise. Dont get a cap. You would be a lot better off upgrading the big 3 and getting a HO alt if you need it. Capacitors are worse for your system then not doing anything at all
Now now, I think you could gut the glove box and wire in a fan to keep air circulating. Maybe cut and hack a duct in from the AC supply into the glovebox. It could be done. would be alot of hassle though.
What about a custom center console? A fan(s) mounted in the sides where the seats would hide them might help in cooling. Might make the center console slightly high, but no one would see the amp. I've only seen cd/dvd players in gloveboxes personally. But just a suggestion. If you do figure out a way in the dash, post it up I'd love to see it. Would be a first to me.
i've seen people install multiple amps in their center console but thats in tahoes and such...
some guy is trying to install an 8 inch sub in the dash of his fusion on DIY right now.
so... anything is possible with enough money and time
