UPS guy loves me
Well maybe he doesn't love me, but knows where I work so he dropped in today. Dropped off my knu order. I had just picked up my sub from the post office only a few hours earlier. Have everything to install now, just need the time.
http://www.blazinjason.com/bl3.jpg http://www.blazinjason.com/bl2.jpg http://www.blazinjason.com/knu2.jpg 15" BL dual 2, cooling, flatwind, daily. Kolossus 1/0 amp kit, with some extra 1/0 to wire SAZ-1500D, and 4g for orion 4002. |
RE: UPS guy loves me
Looks sweet, can't wait to see it all installed, and wish I could hear it, but recording it wouldn't be the same as hearing it in person.
lookin good bro. get that stuff installed!
that kolossus wire is great quality
it's flexibility makes it easier for wiring in diffficult corners. |
Those are some hard hitting subs. Hope you like them!
That Knu kit looks pretty nice....
looks like a beefy sub
Pretty sweet man. Those are gonna sound aweseome.
hows that 1500D goin for ya?
I haven't used the 1500d yet. Been kinda busy (not good enough excuse I know). I am gonna go outside right now and work on my box.
Man tell me about it! I'm proud for ya dude!
Well I finished the box and am still running the wire. Gotta take out the front seats tomorrow so I can get the 1/0 to fit. Can't just run it down by the sill plates like I thought.
edit. Here's the box, turned out pretty good I think. It's about 4 cubes after disc @ 33Hz. http://www.blazinjason.com/fibox2.jpg |
You're sub is in the box upside down! lol
Unless you're installing it sub up, ports back... |
ORIGINAL: drperry You're sub is in the box upside down! lol Unless you're installing it sub up, ports back... |
damn, good work bro.
wish I could build box's |
ORIGINAL: blazinloud damn, good work bro. wish I could build box's |
This is where it stands currently. List of what I still have to do is:
1. Do big 3 upgrade 2. Either upgrade the stock batt, or add one 3. Install 4002 comp amp 4. Install 6.5" components, probably in the stock door locations 5. Build a false floor and mount the amps flushmounted, will hide all the wiring 6. Fix wiring job on the box The speaker wire on the left has been ran to the front doors. 4g ran for the component amp. Everything is there for the amp wiring, so just needs to be hooked up. http://www.blazinjason.com/jimmy6.jpg http://www.blazinjason.com/jimmy5.jpg |
your running both amps off the stock alt?
ORIGINAL: blazinloud your running both amps off the stock alt? |
ORIGINAL: Blazin_Jason ORIGINAL: blazinloud your running both amps off the stock alt? |
Adding a second battery will only really hurt the alt if it's constantly charging a totally dead battery...
It's the equivalent of putting in a higher capacity battery... If adding a second battery will kill your alt even faster, so will replacing the factory sized one with a beefier one... It won't hurt the alt, it'll just take it longer to charge, when they're low. |
