UPS guy loves me
Old Aug 15, 2007 | 07:18 PM
mdemers2006's Avatar
mdemers2006 is an unknown quantity at this point
Default RE: UPS guy loves me
Man tell me about it! I'm proud for ya dude!
Old Aug 18, 2007 | 11:26 PM
Blazin_Jason's Avatar
Well I finished the box and am still running the wire. Gotta take out the front seats tomorrow so I can get the 1/0 to fit. Can't just run it down by the sill plates like I thought.
edit. Here's the box, turned out pretty good I think. It's about 4 cubes after disc @ 33Hz.
Old Aug 19, 2007 | 05:05 AM
drperry's Avatar
You're sub is in the box upside down! lol
Unless you're installing it sub up, ports back...
Old Aug 19, 2007 | 11:30 AM
ORIGINAL: drperry
Yessir
Old Aug 19, 2007 | 01:09 PM
blazinloud's Avatar
damn, good work bro.
wish I could build box's
Old Aug 19, 2007 | 09:12 PM
ORIGINAL: blazinloud
Thanks. It helps to have access to the right tools. I had home depot cut the sheet down to the sizes I needed. Then used a small table saw and radial arm saw to finish what I needed. This was the first time cutting the holes out with a router. Used an old tremmel atachment and a regular router (not plunge) and worked great. Only got to listen to it for a couple mins before a neighbour called and said that the walls were shaking too much at their house. Now I need to deaden the endgate or something cause the rattles are gross.
Old Aug 25, 2007 | 08:34 PM
This is where it stands currently. List of what I still have to do is:
1. Do big 3 upgrade
2. Either upgrade the stock batt, or add one
3. Install 4002 comp amp
4. Install 6.5" components, probably in the stock door locations
5. Build a false floor and mount the amps flushmounted, will hide all the wiring
6. Fix wiring job on the box
The speaker wire on the left has been ran to the front doors. 4g ran for the component amp. Everything is there for the amp wiring, so just needs to be hooked up.
Old Aug 25, 2007 | 10:01 PM
blazinloud's Avatar
your running both amps off the stock alt?
Old Aug 26, 2007 | 02:54 AM
I will upgrade or add a battery and give that a go. After that I might upgrade the alt.
Old Aug 27, 2007 | 02:38 AM
NoPh33rRaCiNg's Avatar
NoPh33rRaCiNg is an unknown quantity at this point
ORIGINAL: Blazin_Jason
dont add a second batt, youll kill that alt even faster. get a new alt and redtop up front, and if u wanted maybe a yellow top or kinetic in the back. then you should be fine with all that and the big 3
