What kind of amp do I need?
Old Dec 30, 2009 | 06:24 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default What kind of amp do I need?
I got a couple 10" Kenwoods that I found on Craiglist. I have no idea of the watts rating but I have found similar ones with a rms rating of 300w. I have a cheap amp in there now but can only hey 1 sub working. Would I need a 600 watt 2 channel to run them both? Thanks.
Old Dec 30, 2009 | 07:41 PM
FlatTopFoley's Avatar
FlatTopFoley has a little shameless behavior in the past
did they already come in a box all wired up?
Old Dec 31, 2009 | 12:41 AM
Yes they did. Would you like me to take one out and see how they are wired?
Old Dec 31, 2009 | 07:07 AM
no, if they are already in a box you can assume they are already wired in parallel.
Old Jan 1, 2010 | 02:26 AM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
i would take them both out and make sure nothing is loose, that could be why only one is working.
the amp should be fine to push them
and if the wiring is all good i would replace the speaker wire.
also push lightly on the non working speakers cone and see if you feel and "grinding" or rough spots. as that can sometimes show that the voice coil has some issues.
also check the terminals with a multimeter set on Ohms and if you dont get anything its a bad speaker.
Old Jan 2, 2010 | 03:06 PM
Benedict1337's Avatar
yea I would take them both out and make sure all the wires are hooked up. never trust the wiring on someone on craigslist haha
JohnBarJB
Sep 28, 2020 07:34 PM
cory.kiel
Apr 25, 2011 06:36 PM
live4liftin
Sep 22, 2010 09:09 PM
Jhop16
Sep 6, 2006 02:42 AM
custom blazer
Headers, Intake, & Exhaust
Jan 6, 2005 05:10 PM
