what type of amp do i want?
i have 2 15" kicker l7 2000w each, i found a couple amps i thought were good but im not sure. how many watts do i want for my amp and whats a good brand?
RE: what type of amp do i want?
What impedance (ohms) are the voice coils?
2 ohms
Try and find an older PPI amp, there excellent in terms of build and sound quality, the newer models are questionable. Alpine and Boston are also good.
what size watts do you think i would need for the amp? and also mono or 2 channel or what. im new with putting a system in and i want my first one to be sick.
single or dual voice coil and whats the rms?
run anywhere from 1500-2000 RMS total
the 15s can take 1000 rms, if you know what your doing. i would recommend the zx1500 or the 2500 and set gains correctly, leaving you with headroom |
If you do find any amp make sure its CEA-2006 compliant |
what vc configuration are thay?if they are single 2 ohm then i'd reccomend the elemental designs nine.1...
Damon |
i was looking at the zx2500 and was leaning more twords that. whats the cea 2006 compliant mean? thanks for all the helps guys
