Go Back  Blazer Forum - Chevy Blazer Forums > Modifications > Audio/Video Electronics
Reload this Page >
When do you need to upgrade the electrical System?
Community
Search
Old 10-15-2010, 11:28 PM
blazerboy001's Avatar
blazerboy001 is on a distinguished road
Default When do you need to upgrade the electrical System?
I am debating on upgrading my current system, and would like to know when I would need to upgrade the Alternator/Wiring etc.
Thanks in advance.
Old 10-15-2010, 11:40 PM
zerepdivad's Avatar
zerepdivad is on a distinguished road
When you pull more current than your current electrical system can handle/put out...
Old 10-15-2010, 11:53 PM
How Do I figure out how much that would be? I'm only pullin about 600 watts for my subs right now, and what I'm eyeballin would be about 4k watts.
Old 10-16-2010, 12:33 AM
69chevelle's Avatar
69chevelle is on a distinguished road
I would at minimum upgrade your main ground wire.
seeing as your amp power wire is probably heavier then the wire that grounds your entire truck..
Old 10-16-2010, 03:30 AM
R2P
R2P is offline
R2P is on a distinguished road
4kW is definitely beyond what your truck can provide stock. With 4kW you would need to upgrade the Big Three, alternator and/or extra batteries. If you want bare minimum though, I would install the system, upgrade the big three, and maybe add a battery and see if you still get significant voltage drop, if so, an alternator or two is in order. 4kW is a lot of power man.
Old 10-16-2010, 03:18 PM
Thought so.
Thanks For the advice guys.
Old 10-16-2010, 09:49 PM
zerepdivad's Avatar
what exactly do you plan on running that's "4000 watts"?
Old 10-17-2010, 12:22 AM
Old 10-17-2010, 12:44 AM
zerepdivad's Avatar
yeah i would't do that........ that is cheap flea market stuff honestly. probably puts out maybe 1/4 of rated power if you're lucky.
Old 10-17-2010, 01:17 AM
69chevelle's Avatar
pyramid... HA. no offence, save your money and get one or 2 GOOD 12"s and it will be louder/clearer...
the main power wire to your truck isn't as important as you are running a seperate one to the amp. main thing is upgrading your ground and alternator wire.
there is a cheap (compared to the 'high output' aftermarket ones) that put out 200+ amps, which is roughly 2600 watts. I will see if I can track it down.
18"s are not good for listening, just spl. can't hit tight bass notes at all.
Quick Reply: When do you need to upgrade the electrical System?
