-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   where is your cb mounted? (https://blazerforum.com/forum/audio-video-electronics-8/where-your-cb-mounted-37311/)
99 blazer 11-25-2009 01:13 AM
ok thinkin of adding a Cb to my 99 blazer where are you mounting it? and any pics?
Sisk 11-25-2009 06:06 AM
There are TONS of pics and threads detailing people's CB radios. I've been debating on where to mount mine as well whenever I get it.
I know people have just mounted to the top of the dash (I'm trying to avoid that for a cleaner look). People have also built brackets to mount down by the cigarette lighter and ashtray. If you have a smaller one you might try and mount it on one of the panels on either side of the steering column...
Just do a little looking around. You'll find some great ideas :)
Monkeyman 11-25-2009 06:59 AM
I had an all-in-one Cobra (everything on the handset with just a little box to connect power and antenna). I mounted the box in the center console with the plug for the handset mounted to the rear of the console. When I unplugged the handset, it was all but invisible and I could toss the handset in the glove box. Got surprisingly good reception with the all-in-one, too.
neo71665 11-25-2009 05:44 PM
I run a uniden pc78 elite and its in my center console.
Biohazed 11-25-2009 06:13 PM
well I used the the fact I have a column ****f to my advantage and mouned it on the console in the front tray, have to take pics of it, used to have it mounted under the dash but it was hardcore in the way
and the one in the K5 is mounted to the roof.
tony991 11-26-2009 09:29 AM
I put my cb in the tray under the cigerette lighter. I didn't even bolt it down, it stays there just fine. I also put a cigerette lighter adapter on the power wire so i could take it out quickly if i needed to.
96chevblazer 12-02-2009 10:10 AM
I have a Uniden pc68xl and it's mounted here, It's just wedged in place, No screws holding it no Velcro neither.
https://blazerforum.com/forum/attach...1&d=1257214040
https://blazerforum.com/forum/attach...2&d=1257214089
https://blazerforum.com/forum/attach...3&d=1257214133
neo71665 12-02-2009 05:44 PM
Originally Posted by Acutttob73 (Post 270268)
i need to mount two amps, one for the subs and one for the door speakers, where have yall been mounting amps? pics please
A suggestion, search then if you can't find an answer start your own thread dealing with the problem you have and don't jack somebody elses thread with something thats not even dealing with the topic at hand.
