Will my system be any louder if I get a more powerful sub?
Right now I have a 10" type S alpine sub powered by a 400W alpine mono amp. My question is will there be any difference if I were to get a 10" type R sub? The type R is more powerful but if the amp stays the same will there be any difference?
Thanks guys!
Type R[*]10" subwoofer with dual 2-ohm voice coils[*]Kevlar® reinforced pulp cone with Santoprene™ rubber surround[*]cast aluminum frame with perimeter venting[*]frequency response: 24-600 Hz[*]power handling: 200-500 watts RMS (250 watts per coil)[*]peak power: 1,500 watts[*]sensitivity: 83 dB
Type S[*]10" subwoofer with dual 2-ohm voice coils[*]pulp/glass fiber cone reinforced with Kevlar[*]Santoprene rubber surround[*]power range: 50-300 watts RMS (150 watts per voice coil)[*]peak power handling: 900 watts[*]frequency response: 30-700 Hz[*]sensitivity: 84 dB
Thanks guys!
There probably won't be a lot of volume difference... But there's probably going to be a little bit of sound quality difference...
Don't ask me which way, I've never heard a Type-R in person, lol, just my Type-S.
most likely wont notice any loudness difference if your keeping the same amp...actually you will probably be a little deeper in tone....do a ported box and upgrade the "Big 3"
ORIGINAL: coplinb
also try upgrading your wiring first before you get a new sub, it can make a diff.
wiring will not affect your sound, but it will allow it to run more efficiently.
less strain on your electrical........but your only running 400 watts. If its going to stay at that the big 3 will be a waste of money and effort.
ORIGINAL: blazinloud
