-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   WIRING!!!!!!!!!!!!!!!!!!!! (https://blazerforum.com/forum/audio-video-electronics-8/wiring-6762/)
a_tack Nov 21, 2006 12:18 AM
so... okay... i know this has been explained to me several times.... but heres the thing...... this is the info on my amp....
» 2-channel car amplifier
» 125 watts RMS x 2 at 4 ohms (250 watts RMS x 2 at 2 ohms)
» 500 watts RMS in bridged mode at 4 ohms (4-ohm stable in bridged mode)
my subs are Kicker CVR DVC 2ohm
the wiring suggested by y'all is this....
http://akamaipix.crutchfield.com/gra...hmDVC_2ohm.gif
but this gives a 2 ohm load...... my amp is only stable at 4 ohms in bridged mode..... so..... what does that mean...lol can I wire them like the diagram or do I need to put one on each channel?
Loud_01_Blazer Nov 21, 2006 01:32 AM
RE: WIRING!!!!!!!!!!!!!!!!!!!!
the way it looks to me, your going to need a different amp to accomadate what your trying to do. because if you wire each sub up to 4 ohms and put each on a channel that will only give you 125 to each. your best bet would be to take your subs back where every you got them and get 2 dual 4 ohm subs or get a mono amp that does 500 watts at 2 ohms...sorry i couldn't be any more help, you may have other options with that setup but none come to mind...if i'm wrong someone please correct me as i would hate to give him wrong info..
a_tack Nov 21, 2006 02:23 AM
can't take them back.... ordered them from crutchfield.... and wouldnt I be pushing 250 to each woofer??? bual channels at 2 ohms = 250 per channel according to the amp info..................... I was advised by several people on here and at a car stereo shop ot get the 2ohm subs..... whats wrong with wiring the subs one per channel? I want it wired at 2 ohms not 4.... so why can't I just plug one 2ohm sub into each channel?? wont that run the 2 ohm sub at 2 ohms????
XBlazer01 Nov 21, 2006 02:32 AM
bridge mono ftw
Thats all the info im willing to give tonight.
My efforts arent appreciated here so yea.
But jsut bridge it mono dude
XBlazer01 Nov 21, 2006 02:33 AM
wire it up to 4 ohms
a_tack Nov 21, 2006 02:33 AM
but my amp is only stable mono for 4 ohms... wil it hurt anything to bridge it mono for 2 ohms?? i cant afford to tear up my amp
Loud_01_Blazer Nov 21, 2006 02:34 AM
NO.
A SINGLE dual 2 ohm sub can be wired to 1 ohm or 4 ohms. you cannot produce a 2 ohm load off 1 dual 2 ohm sub, so no you cant wire each sub to 2 ohms seperately, it just will not work. If you had two dual 4 ohm subs you would be good to go because you could wire each of them to 8 ohms then bridge them together to produce a "bridged" 4 ohm load, or you could wire them each to 2 ohms and run one to each channel, my advice get a different amp cuz it's just not going to work..trust me.
a_tack Nov 21, 2006 02:36 AM
how the eff do I wire them to 4 ohms? i only have diagrams for .5 ohms, 2 ohms and 8 ohms
XBlazer01 Nov 21, 2006 02:37 AM
Just rewire it.
but if you see it fit to get a new amp
JUMP on this
http://forum.realmofexcursion.com/sh...212#post210212
Loud_01_Blazer Nov 21, 2006 02:40 AM
you will have to wire EACH one to 4 ohms CLICK THIS and look at option 2.
