Wiring in component speakers
Hi guys. I have a '00 Blazer with blown stock paper speakers in the door, and factory tweeters in the dash. I do have an aftermarket stereo from about 10 years ago that puts out the standard 50wx4. I want to put in a cheap set of components (like $50-$60) to replace those busted stockers.
My question is the wiring. How do I get the wire from the crossover (mounted in the door) to the tweeter mounted in the dash? Is there a shortcut where I can reuse the stock wire? Where is the factory crossover located for the factory tweeter, on the wore somewhere or soldered onto the tweeter itself? Will I have to pull my dash all apart to run new wiring back there? I'm not interested in drilling holes to mount the tweeter anywhere else, this is car isn't really a daily driver, just something for the nanny to haul the kids around, but the stereo needs to work. I'm open to going 3-way and not bothering with the tweeters if you guys say it isn't worth it. Just leave the stock tweeter alone, or disconnect it in that case? Thanks |
