-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Wiring Power inverter to ignition source (https://blazerforum.com/forum/audio-video-electronics-8/wiring-power-inverter-ignition-source-73914/)
Unlimitedsp 09-21-2012 12:52 PM
1 Attachment(s)
So Im installing a power inverter in the rear and want it to be wired to an ignition source in order to avoid manually flipping it on and off. This is what im running.
After some thought this is what I have come up with.
Attachment 32803
I plan on tapping into the switch contacts on the inverter and run a relay to it from an 12V switched ignition source. That way the inverter is flicked on and off with the ignition. I just want some input to make sure I am correct on my wiring and relay setup.
