Working on some door pods (first gen)
#21
RE: Working on some door pods (first gen)
Finally found a place in town today that had T-nuts small enough. Set the speakers in and got the t nuts sunk in and held with epoxy as well. Then mounted the ring for the mid. The tweeter ring was too large and wasn't going to fit very well. So I sanded them down, which now I wish I had only done the top part and the bottom. That way I would have more surface area for the fiberglass. Or I could have had the mount made from 1 piece of mdf. Waiting for some of the wood glue to dry, then I might try and wrap it. Would really like to get that started.
#22
#23
Looks good man... where exactly on the door are they gonna go? I want to eventually put some tang band midbass drivers in my doors.
#24
These go on the door panels, where the map pocket is. Just drill out the plastic rivets that hold the plastic map pocket and carpet to the panel. I'm curious as to what you guys use for this type of thing, fiberglass mat or cloth/weave?
#25
ORIGINAL: Blazin_Jason
Any pics on the doors.
#26
nice job man! i didnt know you were over here. i had the exact same speakers in my camaro and they worked great. had them mounted flat, or paralell to the door, and sounded awsome. but that was the stock location for them in the camaro. the speakers i took out obveously had come in contact with water, and they were fine. i am sure my new ones did too, but they worked fine untill i sold it.
#27
I used about 8sq. feet of mat on them both. Sure isn't the most fun stuff to work with. After doing so I was looking on s10forum (Zygoats favourite) and looks like buddy there was saying to use weave. Looks like the cloth stuff might be easier to work with. I don't have any pics of them on the doors yet, as I still need to sand them down a little, then put on some kitty hair.
#28
DO NOT use the weave type.
#29
No I used felt for the form as shown in the pictures. Then I added about 3-4 layers of mat.
#30
Too late now but fleece aint the best stuff to use, it it soaks up too much resin, makes most guys not use enough layers of glass cause they think its stronger that it really is. Three to 4 layers aint really enough and will crack if bumped too hard with a careless foot, your gonna want to add another 3-4.
Spandex or even an old t-shrit work better for a backing, stays thinner with the right amount of layers of glass. Also using this if it doesn't look thick enough it aint.
