-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Would this fit in a '93 S10 Blazer? (https://blazerforum.com/forum/audio-video-electronics-8/would-fit-93-s10-blazer-96172/)
'93BLZR 01-21-2018 09:19 PM
https://www.bossaudio.com/auto/car-v...audio-bv9351b/
As much as I love my factory Delco unit, I need something bluetooth enabled.
error_401 01-22-2018 02:31 AM
The 93 could have the same problem as the 94.
The audio unit is 1 1/2 size but the depth is not a standard size. At least not for our European ISO DIN standards. I had to make up a spacer to fit a 1 size DIN frame and cheapo radio.
Planning to replace with a 1 1/2 size or double DIN GPS/RADIO unit if it should fail.
You probably have to look and measure.
richphotos 01-22-2018 11:22 PM
It can fit, but you have to cut things and move things around. Google double din in first gen blazer
error_401 01-23-2018 03:03 AM
That is my plan too.
Remove the ashtray, move the air outlets or create very slim ones on top,
make a fibreglass cover that fits a double DIN frame and makes more room towards the back.
'93BLZR 01-23-2018 10:44 PM
Ok. I just remembered I had purchased a complete audio kit for my Ranchero... I have a BOSS 500W amp, wiring kit, BOSS bv7335b and some speakers (which I don't need in my Blazer). I'm just gonna use this instead... Much easier
Has anyone ever used this? https://www.hifisoundconnection.com/...C2-RadioKit251
I will just make it easier for myself if I can use this
error_401 01-24-2018 04:22 AM
I took the old harness and pinned out the radio side adapter. Then pinned short lengths of cable and a connection box to that so it plugs into the OEM harness.
Antenna was (still is) a nightmare. The coax is too short and I needed an extension for that.
The old style antenna on the fender is also a bad placement for VHF radios.
When it comes to changing the engine I'll probably also do an upgrade to DAB-T and add a Bluetooth box to stream off my phone.
'93BLZR 01-25-2018 10:38 AM
The antenna was (still is) a nightmare. The coax is too short and I needed an extension for that.
I, unfortunately, don't have the patience for that... So I just have to hope that it works :icon_lolsign: and the kit comes with an antenna adapter
