03 Blazer LS rebuild questions
Im finally ready to rebuild my 2003 Blazer LS 4WD. Im looking to replace the engine, transmission, exhaust, etc.. Id really like to turn it into a high performance beast (still street legal) as much as I can.
For the transmission I was looking at picking one up from PerfomaBuilt.
Any recommendations where to find a high performance 4.3L long block engine?
I am very open to any suggestions or other recommendations to include with a new engine and transmission.
What exactly are your goals with it?
Seeing as its a 4x4, but wanting to upgrade it but keep it street legal, like offroading or street queen?
Personally would do more a Solid Axle swap, if keeping 4.3 and have better offroad capabilities, than worrying about a stout engine... If keeping it more 'street' I would do a V8 swap. Vortec V8 (SBCs) are easy to come by, or LS swap, but engine swaps can get expensive quick (ask me how I know!)
I would be driving it to work 2-3 times a week and doing some off-roading with it when I go camping. So stay with a 4.3L v6?
It currently has about 183,000 miles on it and the transmission is definitely starting to go. I absolutely want to hold on to it as it has some sentimental value to it.
My dad was a mechanic in the Air Force and made a career out of it. I bought this truck new and him and a friend he served with always helped me maintain it. My dad has since passed but his friend is still around and has a nice shop to work out of. He always tells me that he would help whenever I wanted to start my rebuild.
Depends how involved you wanna get.
4x4 harder for LS swaps than 2wd, so only one company I know of makes mounts, or you make your own.
current performance can make plug n play harness so all factory gauges work, or you can go holley terminator for ecu but is $2500 alone for that.
oil pan is a big issue for 4x4 due to front dif, milodon and canton do make swap pans, but are pricey at $7-800 for just oil pan stuff (you can also modify a factory alu pan if you have the fab skills.
can get away with stock rad far as I know, but best to inset it into the rad for clearance (adding 2 more cylinders so space between engine in rad is much tighter.
i am currently working on doing an LS swap (but going awd) and my budget is 20-25,000$ things get real pricey when you start doing performance mods
