‘03 Blazer LS rebuild questions
I’m finally ready to rebuild my 2003 Blazer LS 4WD. I’m looking to replace the engine, transmission, exhaust, etc.. I’d really like to turn it into a high performance beast (still street legal) as much as I can.
For the transmission I was looking at picking one up from PerfomaBuilt. Any recommendations where to find a high performance 4.3L long block engine? I am very open to any suggestions or other recommendations to include with a new engine and transmission. |
What exactly are your goals with it?
Seeing as its a 4x4, but wanting to upgrade it but keep it street legal, like offroading or street queen? Personally would do more a Solid Axle swap, if keeping 4.3 and have better offroad capabilities, than worrying about a stout engine... If keeping it more 'street' I would do a V8 swap. Vortec V8 (SBCs) are easy to come by, or LS swap, but engine swaps can get expensive quick (ask me how I know!) |
I would be driving it to work 2-3 times a week and doing some off-roading with it when I go camping. So stay with a 4.3L v6?
It currently has about 183,000 miles on it and the transmission is definitely starting to go. I absolutely want to hold on to it as it has some sentimental value to it. My dad was a mechanic in the Air Force and made a career out of it. I bought this truck new and him and a friend he served with always helped me maintain it. My dad has since passed but his friend is still around and has a nice shop to work out of. He always tells me that he would help whenever I wanted to start my rebuild. |
Also, how much extra is involved in swapping over to the 5.3L v8?
Depends how involved you wanna get.
4x4 harder for LS swaps than 2wd, so only one company I know of makes mounts, or you make your own. current performance can make plug n play harness so all factory gauges work, or you can go holley terminator for ecu but is $2500 alone for that. oil pan is a big issue for 4x4 due to front dif, milodon and canton do make swap pans, but are pricey at $7-800 for just oil pan stuff (you can also modify a factory alu pan if you have the fab skills. can get away with stock rad far as I know, but best to inset it into the rad for clearance (adding 2 more cylinders so space between engine in rad is much tighter. i am currently working on doing an LS swap (but going awd) and my budget is 20-25,000$… things get real pricey when you start doing performance mods… |
Maybe I stick with the 4.3. Where would be a good site to shop around for a crate 4.3?
Are there any issues trying to use the LV3 4.3 that’s used 2011 Silverado 1500? Looks like those put out more HP, around 285.
| All times are GMT -5. The time now is 12:36 AM. |
