1995 СPI Blazer refreshing
1995 СPI. Was in very-very bad condition, but now i`m trying to repair everything in it.
I found this Сhevy in my father`s garage last year (he participates in the war in ukraine right now). First I found a rear axle oil leaking. Oil was leaking through a crack in the axle housing near axle bearing. I tried to weld a crack. That didn't help. I had to buy a differential housing, axle shafts, bearings, and seals. After that there were no breakdowns for a couple of months. But later there was a problem with the hot start(didn`t fix it yet), with rear u-joint, leaf springs, and much more. I have disassembled the car a bit. Next step: -refresh engine a little. -redo vacuum lines -repair wiring -go to carb ( I'm sick of a fuel leaking) Current state of blazer on this photo: https://cimg4.ibsrv.net/gimg/blazerf...f6248b740c.jpg |
Good luck with the Blazer. Keep us posted and be sure to ask questions.
Good luck with the Blazer. Be sure to ask questions. And good luck to your father!
