1999 4x4 blazer 4dr rebuild
Replaced transmission (automatic)
Replace left side drive axle Replace left side front bearing Replaced vacuum lines Replaced front drive shaft Replace front dif left side seal Replaced fuel filter Replaced door pin bushing Changed fluid in transfer case Replaced damage rear def fill plug Replaced water pump Replace shocks Replace brakes Re-balanced tires Replace idler arm Replace right front wheel bearing Replace right front axle Re-tighten shocks Installed keyless entry Replace timing cover seal Replace serpentine main belt Replaced idler pulley Replaced belt tensioner Tested fuel pump pressure Replaced radiator Replaced radiator hoses Replaced lower ball joints Replaced left upper ball joint Replaced dist. Cap & rotor and wires and plugs Replaced heater core Replace heater hoses Replaced rear tires Replaced fuel pump for the second time (Delphi this time not Airtex) Replaced fuel filter with new fuel pump Installed an Add-A-leaf kit to rear springs Things left to do. Transfer case tail shaft seal Fix exhaust leak on left side Replace front tires Replace oil in rear end Replace or fix passenger side recline lever Reinstall driver’s side door spring Install steering stabilizer |
Replaced windshield last year (lawn mower + rock!!! bad day)
Cleaned MAF Sensor Replaced Air filter basically trying to get everything back up to standard that got neglected over the last 8 years of ownership (while the wife drove it) other things not sure what to do about. driver sided seat-belt retracter is really slow. drive ability issue under moderate acceleration up hill there is a breif point of rough acceleration or cutting out but you can push on through it or let up on it and it goes away (possible TPS sensor?, or MAP Senors no codes, no CEL light) also have the morning loud ticking lifter that quiets down after it warms up, but still tick all the time. |
another issue under heavy acceleration I have Cam rattle or pinging.
I also seen the tread about the hose for the secondary air pump that just sticks out in the engine compartment.
Is there a cheaper way to fix it other the GM's $50 hose kit?? |
1 Attachment(s)
replace rear transfer case seal, leveled center drag link, re-tighten exhaust flange, replace all four tire (235 75 R15) removed & clean throttle body. repaired driver's side door speaker blazerleft.jpg
replace that last ball joint now all have been replace, now of to the alignment shop tomorrow, plus after the 5th tightening the exhaust leak is gone!!!!
the project is almost done. just a few more things left on the list |
out of the alignment shop, pretty much everything was out of spec. toe-in by quite a bit.
jeez, it should be about brand new now :)
That is exactly what I thought. I think I would of taken a vacation to Brazil & bought a new one & wouldn't of spent much more.
well in this county they tax us to death on property tax, the taxes on the 99 are $135 a year. as long as I can keep it running the better off I am our 2006 is $425 a year. and the old beast only has 3 little dings in it, otherwise it's perfect, interior is almost perfect, and now everything works except the recline lever, 3rd brake light, and driver's side door spring. it runs and drive like a new one almost. I have most of the squeaks and rattles out. Wednesday I checked the mileage and it getting 19 to 20 mpg. NADA says it worth $2950 I bet I can drive that much out of it in the next 3-4 years. insurance is only $48 a month, its 13 years old and only has 133,000, I use it for shooting matches, fishing, and hunting.
I can't buy any thing out on the open market to replace it under $5000 around here. example 2005 trail blazer 99,000 miles 4x4 $10,999 and it rougher than mine is, and it 6 years old. and it get worst mileage than the one I got. plus mine is paid for and the insurance on 2005 it $140 per month the 99 is $55 per month |
