1999 Blazing Build
Old Jan 19, 2016 | 05:59 PM
Metalslug137's Avatar
Metalslug137 is on a distinguished road
Post 1999 Blazing Build
So I am starting this a little late (one year), but want to now start my build thread. I will date all of the previous pictures starting from when it was at the auction.
Hope you all enjoy and do not mind my questions on the way.
Old Jan 19, 2016 | 06:01 PM
Default December 2014
Here is the Blazer sitting at an auction lot. I did not purchase it from the auction but the mechanic who I bought the car from did.
Old Jan 19, 2016 | 06:03 PM
Default January 2015
Here is the day the Blazer was purchased
Old Jan 19, 2016 | 06:14 PM
Default June 2015
Did not do much to the Blazer for first couple of months, but the first install was the stereo. I changed the 6.5" door speakers and front 4x6's with Sony's. I added 12" Kicker Sub with Boss (sorry!!) 1100 watt amp. The amp actually works great. The Head Unit is Kenwood and the mount was purchased from Crutchfield. The entire install took about 4.5-5 hours.
Attached Thumbnails 1999 Blazing Build-stereo2.jpg   1999 Blazing Build-stereo3.jpg
Old Jan 19, 2016 | 06:18 PM
Default June 2015 (2)
Since I am located in the state of Florida, I decided it was time to get the front windows tinted.
Old Jan 19, 2016 | 06:25 PM
Default July 2015
With some time on my hands, I decided to restore my salt corroded Oldsmobile rims(still looking for new ones) with the 3M wheel restoration kit. I also got the tires flipped as I am not a big fan of white walls.
Attached Thumbnails 1999 Blazing Build-img_20150810_121557011.jpg   1999 Blazing Build-img_20150810_172931188.jpg   1999 Blazing Build-img_20150807_154038326.jpg
Old Jan 20, 2016 | 07:46 AM
Tajohns34's Avatar
It looks good. I like the 2 tone color combo. The wheels cleaned up pretty nice.
Old Jan 20, 2016 | 12:39 PM
Thanks, you don't really see the 2 tone colors much. And the wheels have kind of lost their shine already.
Old Oct 24, 2016 | 07:35 PM
Default Lift!!
I have finally saved enough for the day of the lift. I went with superlift control arms paired with moog ball joints and 2 inch lift shackles in the rear. The superlift control arms put the ball joint at a angle to reduce wear. I got about 1.5 inches in front and 2 in back. And I got a 3 year alignment program at tires plus. How's it look?
Old Oct 24, 2016 | 07:40 PM
Default Reapirs/Mods
Figured I would share all and everything I have done to the Blazer to this day.
Monroe Shocks
Rear Brake Calipers with Pads
Re-surfaced rotors
AC Delco Fuel Pump
Lower intake manifold gasket (Fel-Pro Gasket)
Passenger Side Constant Velocity Axle
Spark Plugs
AC Delco Cap and Rotor
AC Delco Plug Wires
Passenger Side Rear Shackle
AC Delco Engine Thermostat
Radiator
PCV Valve
Turn Signal Control Module
AC Delco Electronic Conversion Injectors
Glass Pack Exhaust
New Fuel Lines
Driver Side Hub Assembly
Moog Ball Joints
Superlift Control Arms
Rear Differential Serviced
