2000 Blazer New Project
Old Aug 16, 2012 | 12:02 PM
  #61
musclemasterflex's Avatar
musclemasterflex is on a distinguished road
About $150 from Autozone. Lifetime warranty. For the 2006 Escallade.
Old Aug 16, 2012 | 01:46 PM
  #62
So the fuel pressure sensor Code PO452 went out and I had to replace it. It is located on the fuel pump. You MAY be able to remove this by only lowering the tank, however when I pulled on it, it broke off. So I had to drop the tank and pull the pump to get it out. The seal on the pump was stretched but I couldn't find a local spare so did the best I could to put the ring back in. Went to fill it up and the moment the pump clicked off full, I heard a spill. The pump leaks.... Ordered the replacement ring from amazon, now to burn down the tank and do it all over again. FML
Old Aug 16, 2012 | 04:29 PM
  #63
Blue thunder 2000's Avatar
Blue thunder 2000 is on a distinguished road
i like what im seeing! my blazer is pretty much the same...only its stock.. haha.
got an old foxbody stang if you ever want one to fix up
Old Aug 17, 2012 | 03:37 PM
  #64
I built an 83' Foxbody a few years back with 450hp... It assploded... haha I avoid Fords since that...
Old Aug 17, 2012 | 03:40 PM
  #65
I should add I also swapped the coil with an accell one. I have noticed better and smoother throttle response.
Old Aug 30, 2012 | 10:34 AM
  #66
Got the new seal in so I dropped the tank. Decided to completely drain and wipe it down. I have to put a tiny bit of oil on the seal so that I could get it in. If you have to swap the fuel pump, I recommend doing this. It makes it a million times easier. While the tank was out I decided to swap the passenger leaf spring finally. The shackle bushing was completely shot on this side. It fell out as soon as I removed the bolt. At least it wasn't seized like the other ones. I took a torch and melted out the rubber from the metal cup. Cleaned it with paint thinner, greased it up and pressed the energy bushing in. I also did the same thing to the driver side since I never got to that bushing before on account of the fuel tank and charcoal canister being in the way. The ride is WAY smoother now. And I am getting a LOT better mileage with the new fuel pressure sensor.
Old Sep 20, 2012 | 05:57 PM
  #67
So I had issues with the abs activating whenever I would hit bumps. I also had vibrations at about 55. I decided to Finally replace the passenger side hub. It was on $55 on Amazon
Precision 513124 Hub Assembly : Amazon.com : Automotive Precision 513124 Hub Assembly : Amazon.com : Automotive
Worth every penny. All those issues are resolved. I'm about to order the driver side now. Replacing the hub was SUPER easy took 10 minutes.
Old Sep 20, 2012 | 06:04 PM
  #68
I also just got the weld for the eyelet on the driver side lower control arm redone and sided the arms for the rear sway. Makes a huge difference having both hooked up again. Love how it rides now. I also just finished the cai. Here's the pic.
Old Oct 12, 2012 | 11:53 AM
  #69
Just added a rack on the top Looks pretty awesome Next is the electric fan
Old Oct 12, 2012 | 11:54 AM
  #70
