2000 Boring Blazer Build
#71
installing the Ebay CAI
I decided to install a cold air intake. Mainly because my stock air box was cracked from the accident before I bought it. It was working fine but it kept coming loose and leaking. Also when I did the intake I did a major cleaning of my throttle body and MAF sensor (used MAF cleaner). here are some pictures.
I probably won't be doing much until spring, I have some projects around the house and Christmas coming up. I do have a couple small projects planned for the upcoming weeks.
#73
Looks like your going down the same paths I did. You even have the same crappy wrangler rt/s tires I had. Fair warning they SUCK *** in snow. Here is a link to my build.
Lets make it better then when I got it.
#76
My wife's subaru has bald tires so that is top priority in tire purchases right now, then I need to fix my sagging rear leafs. Any suggestion on what I should use instead of the good years?
#79
So I decided I would to the 4 headlight "upgrade". I tried the 1 wire method. I spliced into the yellow wire from the low beam on the passenger sided and ran it to a ground. That is it. I didn't solder this or even ground it that well. This was only temporary to test it out. I want to eventually run the ground through a fuse and a switch on my dash somewhere. Here are the pics.
