4l60e to 5spd
Old Jun 10, 2010 | 09:53 PM
98odgblazer's Avatar
98odgblazer is on a distinguished road
Default 4l60e to 5spd
well after little thought ive come to this conclusion...automatic transmisions are garbage, my blazer is 4wd i assume i can use the transfer case and get a clutch pedal assembley and a trans and it should go in with little problems am i correct?
Old Jun 12, 2010 | 01:06 AM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
idk, but that would be an awesome build thread *HINT* *HINT*!!!
Old Jun 12, 2010 | 01:30 AM
kiwiblazer's Avatar
I recall reading this a while back. Been discussed a number of times.
https://blazerforum.com/forum/showth...o+manual+trans
Hope it helps - Amazing what you can find with the "search" function above.
Old Jun 21, 2010 | 06:28 PM
old skool luvr's Avatar
good luck on finding a donor truck, i've been looking for one for about a year now-and that's just for the pedals! (i still have one of my 4WD 5spds from my other truck).
otherwise, it would already be in my build thread.
Old Jun 21, 2010 | 11:48 PM
Hanr3's Avatar
Ummmm, the 700R4/4L60/4L60E tranny is in EVERY rear wheel drive GM vehicle since the early '80's and it is revered as the BEST auto tranny ever built.
With that said, nothing compares to a manual tranny.
As for your question, depends on what you mean by little problems.
Yours being a '98 means it's computer controlled, so you have to deal with the puter and reprogramming it. You wil also have to remove the wiring harness, and rewire the VSS. Not too mention the manual tranny and auto tranny are different lenghts, swap driveshafts, tranny cross brace location. Yes you will need the peddles as well as the hydrolics for the manual tranny. That is assuming you can find a manual that will bolt up to your V6 and to your t-case and the other parts to make it all work.
Old Jun 22, 2010 | 01:05 AM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
^^^^ Agreed
BlazeringSaddles
34
Nov 29, 2009 01:35 AM
Blazin_1t_up
Dec 22, 2008 06:09 PM
spunbearing
Sep 26, 2007 05:01 PM
gravix
Feb 10, 2006 04:21 PM
wolfe1967
Aug 29, 2005 12:27 AM
