-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   4l60e to 5spd (https://blazerforum.com/forum/builds-48/4l60e-5spd-45584/)
98odgblazer Jun 10, 2010 09:53 PM
4l60e to 5spd
well after little thought ive come to this conclusion...automatic transmisions are garbage, my blazer is 4wd i assume i can use the transfer case and get a clutch pedal assembley and a trans and it should go in with little problems am i correct?
Ryanmatt135 Jun 12, 2010 01:06 AM
idk, but that would be an awesome build thread *HINT* *HINT*!!!
kiwiblazer Jun 12, 2010 01:30 AM
I recall reading this a while back. Been discussed a number of times.
https://blazerforum.com/forum/showth...o+manual+trans
Hope it helps - Amazing what you can find with the "search" function above.
old skool luvr Jun 21, 2010 06:28 PM
good luck on finding a donor truck, i've been looking for one for about a year now-and that's just for the pedals! (i still have one of my 4WD 5spds from my other truck).
otherwise, it would already be in my build thread.
Hanr3 Jun 21, 2010 11:48 PM
Ummmm, the 700R4/4L60/4L60E tranny is in EVERY rear wheel drive GM vehicle since the early '80's and it is revered as the BEST auto tranny ever built.
With that said, nothing compares to a manual tranny.
As for your question, depends on what you mean by little problems.
Yours being a '98 means it's computer controlled, so you have to deal with the puter and reprogramming it. You wil also have to remove the wiring harness, and rewire the VSS. Not too mention the manual tranny and auto tranny are different lenghts, swap driveshafts, tranny cross brace location. Yes you will need the peddles as well as the hydrolics for the manual tranny. That is assuming you can find a manual that will bolt up to your V6 and to your t-case and the other parts to make it all work.
Cavalier z24 Jun 22, 2010 01:05 AM
^^^^ Agreed
