74 k5 blazer project build
10 Attachment(s)
This project has been awhile in the making. I have never posted anything before so I figured why not start. So first thing is, I traded a 93' jeep grand cherokee for my beastly 74. It was kinda beat up and ran ....sort of. It would die every time you came to a stop. I decided I wanted to go with red and black instead of the blue color. First thing I did was gut the interior. I tore everything out, dash and all. I then patched, sanded, grinded, and cleaned the floors. it was tough. My next step was painting the floors with rustoleum then covering that with bed liner. I then sanded and painted the metal parts of the dashl and patched the dash pad with fiberglass then painted it black. That was very very tough. I do not recomend patching the dash pad. It was trial and error and took forever to get the cracks not to show. I then installed a cup holder thing in the middle and painted the seat brackets. I put in a new 4x4 shift knob and boot. Put on a new steering wheel, turn signal knob and shifter. I painted the column. Painted the instrument panel and put on white gauges. I also installed red bulbs behind for a red glow. The column shifter was a pain. I had to grind the new chrome one to fit. I also cut the pedals which was actually pretty hard cause I had to use a jig saw through that thick metal. I took off the doors and painted the doors and panels. I cut the door locks so they did not stick so high up and I bought a rear floor mat. I now am in th process of tearing apart the engine to begine the rebuild. Its a 68 327 with 2.02 camel humpers. Any suggestions?
More pictures
10 Attachment(s)
here are more pictures of the k5
even more pictures
12 Attachment(s)
here are even more pictures of the project
still more pictures
12 Attachment(s)
yep still more pictures of the project
the last set of pictures
last set of pictures so far.
Great job on the interior man. I am starting the same process. What kind of bedliner did you use? I have heard the raptor stuff is pretty descent.
I used the herculiner. It was actually in the pile of junk inside the vehicle. Two cans of it, so I was pretty excited! It was ok though, It came out kinda bumpy so I think I am going to have to put vinyl flooring over that.
