'94 Jimmy build
Well, I was set on a v8 swap, until I started discovering how good the CPI 4.3 is power wise. It makes more power than a TBI 305, and about as much HP as a TBI 350. So, I decided to build up what I had, instead of swapping in a V8.
The truck is a 4.3 CPI, 4x4, 4 door, automatic, and I swapped in a manual transfer case. I had tested my painting skills on it, having done a complete repaint, and kept it otherwise stock. I decided to wait until finished to upload all my pictures, and do it all in one shot. SO, here's the pictures. When I first got it, on 31's with no lift, and lots of rubbing when turning: http://i293.photobucket.com/albums/m...ywt/jimmy1.jpg Cleaned up, on stock-size tires http://i293.photobucket.com/albums/m...t/S3010181.jpg After home-done paint job, roof rack removed http://i293.photobucket.com/albums/m...t/S3010390.jpg http://i293.photobucket.com/albums/m...t/S3010392.jpg |
Engine before teardown, lots of mud, it's been through some stuff
http://i293.photobucket.com/albums/m...1014111555.jpg http://i293.photobucket.com/albums/m...014111555b.jpg Some cleaning and painting http://i293.photobucket.com/albums/m...1102111131.jpg http://i293.photobucket.com/albums/m...1102111939.jpg Back together after all the work, I'll describe at the end http://i293.photobucket.com/albums/m...0211121659.jpg http://i293.photobucket.com/albums/m...211121659a.jpg Body lift installed, with stock size tires. I redid the gold pinstriping with silver, and replaced the stripe on the side trim since the gold was wearing off http://i293.photobucket.com/albums/m...417121656a.jpg |
All done, new tires on it, been driven about 25 miles
https://blazerforum.com/forum/member...work-22050.jpg https://blazerforum.com/forum/member...re-a-22051.jpg https://blazerforum.com/forum/member...re-a-22053.jpg https://blazerforum.com/forum/member...re-a-22054.jpg |
looking good man im planning a body lift for mine in the future
Im curious what you did with the bumpers |
So here's what's happened. I did a 3" body lift, added 31" tires. I also did a top end rebuild. I kept the stock cam, as I understand it's the best 4.3 v6 cam that came stock. I did light cylinder head porting, and added 1.6:1 roller rockers with new valve springs. The whole top end has new gaskets. I also replaced the CPI unit, added an MSD coil. The exhaust has a hi-flow cat, and added a dynomax single-out exhaust with a stainless tip. The old exhaust was just beat and had numerous holes. There's a bunch of other stuff too that I'm forgetting, I'm sure. It runs like a raped ape at the moment. Stock it had 200 HP, I'd estimate it to have gained 20 or so HP.
I spent all winter chipping away at it, cleaning up all the parts, running a tap and die over all the bolts/bolt holes, and making the engine as new as possible. I'm hoping it lasts a long time. I'm doing all of this so I have a sort-of online diary of the build. Any questions, feel free to ask |
(Post 516234)
yea im looking into a 2 inch body lift . I dont think the gaps should be that bad but yea =D
We will see when i get to it your truck looks great tho |
clean
