95 to 98 headlight conversion
Last week I was pulled over for a burned out headlight on my 1995 blazer. Thankfully I was given a warning and sent on my way. This got the ball rolling for doing the headlight conversion that I have wanted to do for a while now. I went to the junkyard and got a chrome bumper, valence, grille, and headlights off of a 1999 blazer all for $140. Sorry if the pictures aren't the best quality, I was too lazy to get my DSLR camera out so I just took the pictures with my phone.
This is what it looked like when I started: http://i145.photobucket.com/albums/r...-41-43_280.jpg Once I removed the grille and bumper: http://i145.photobucket.com/albums/r...-57-37_623.jpg Hood and lights removed: http://i145.photobucket.com/albums/r...5-39-33_82.jpg I loosened both fenders and removed the radiator support http://i145.photobucket.com/albums/r...-39-25_496.jpg Out with old: http://i145.photobucket.com/albums/r...-49-28_799.jpg In with the new: http://i145.photobucket.com/albums/r...-49-23_201.jpg |
I removed my air bag sensors and bolted them to the newer support:
http://i145.photobucket.com/albums/r...4-56-36_15.jpg Before I put the newer radiator support back in I gave it a quick coat of paint: http://i145.photobucket.com/albums/r...-20-43_828.jpg New rad support installed: http://i145.photobucket.com/albums/r...4-17-49_75.jpg Chrome bumper installed and headlight wiring with 10ga wire and relays http://i145.photobucket.com/albums/r...-20-14_298.jpg And finally everything mocked up http://i145.photobucket.com/albums/r...-13-52_621.jpg Things left to do: New headlights (the ones from the junkyard are broken beyond repair) Fabricate/ bend bumper support brackets Get new bulbs (hopefully LED) |
I like !
I'm going to be doing the same thing with my '96 soon. How long has everything taken you so far? How bad was it to switch out the headlight wiring to a thicker gauge with the front end apart?
I'm going to have to do the same thing to my Jimmy here eventually.
If you don't mind: how easy was it to loosen those fenders? What more would you have had to do to remove one completely? I'm not asking for a procedure, just a general impression. Is the whole job the piece of cake it looks like? How long did it take to complete (minus paint-drying time)? |
Originally Posted by melliferal
(Post 498386)
Originally Posted by tibby
(Post 498384)
Headlight Rewire (Sealed Beam) Headlight Rewire (98 and newer)
(Post 498386)
If you don't mind: how easy was it to loosen those fenders? What more would you have had to do to remove one completely? I'm not asking for a procedure, just a general impression. Is the whole job the piece of cake it looks like? How long did it take to complete (minus paint-drying time)? Back to a little progress, I got new headlights http://i145.photobucket.com/albums/r...-21-47_436.jpg And if someone is interested in converting sealed beam lights to composite this is a How-To I found on S10 Forum How-To Convert Sealed Beam To Composite Headlights |
Okay, hopefully my install will be a little quicker because I'm already running composites and the new front end have composites.
Nice freaken job man!! looks way better!
