96' 6in lifted ls 4dr
Ford 9in front and rear , new 4.3 vortec engine , rebuilt trans 33in pro comp wheel and tire , hella lights , full sound system , but I need some help figuring out if I need the vacuum accumulator for the transfer case to shift since I am using ford 9 inch??
front 9" very custom!! if it has locking wheel hubs, no.
pics of the setup, please :) |
How do I post pics hahah
you can copy a link from anywhere you have them on the internet. or, post them in your garage on this forum.
Originally Posted by Lifted89
(Post 553892)
You're going to want to disconnect and plug the vacuum feed going to the t case so you don't have a huge vacuum leak when you switch into 4wd. |
Originally Posted by KM346
(Post 553917)
Vacuum switch on the t-case is used to engage the front axle on the stock IFS. The t case engages via an electric motor or manual lever on these trucks, no vacuum required.
(Post 553919)
Yeah I was pretty sure it was electronic , but I wasn't sure that if the diff. Didn't lock that it wouldn't tell it to go into 4 wheel .
Originally Posted by Diaita
(Post 553894)
your link is not working
| All times are GMT -5. The time now is 04:15 AM. |
