99 Jimmy 1 ton build
Joined a few months ago , posted a few pics and have been getting a lot of requests for build info. so I figured I would post a build thread.
here is what i started with : bone stock 99 Jimmy 2 dr with 150k http://i4.photobucket.com/albums/y15...immyrig164.jpg I had a set of 1 ton Axles from a 98 Dodge just taking up space. so...... http://i4.photobucket.com/albums/y15.../misc10008.jpg I decided they would go great under the Jimmy , so the cutting began http://i4.photobucket.com/albums/y15...immyrig166.jpg http://i4.photobucket.com/albums/y15.../therig007.jpg http://i4.photobucket.com/albums/y15...immyrig173.jpg Rear was first , because it was much easier .... Stock springs with a couple of leafs added , SOA. http://i4.photobucket.com/albums/y15...immyrig170.jpg On to the front , homemade cross member , Dakota leafs SOA. Axle set 2" foward , Astro van gear box and TJ drop pitman arm. 1.5 DOM steering with 7/8 heims http://i4.photobucket.com/albums/y15.../therig003.jpg http://i4.photobucket.com/albums/y15...immyrig172.jpg http://i4.photobucket.com/albums/y15.../therig005.jpg http://i4.photobucket.com/albums/y15.../therig008.jpg |
Picked up a set of Military H1's with 37" Goodyears, recentered the H1's to 3"back space with Copperhead Fab centers:
http://i4.photobucket.com/albums/y15.../therig016.jpg Custom built front bumper all made from 3/16th plate http://i4.photobucket.com/albums/y15.../therig018.jpg Ended up with this : http://i4.photobucket.com/albums/y15.../therig015.jpg First trip out in the woods and I popped the motor http://i4.photobucket.com/albums/y15.../therig023.jpg So out with the old and in with the new ...... http://i4.photobucket.com/albums/y15...ild/therig.jpg While it was down for the motor swap I went ahead and pulled the trans and transfer case . Had the 4l60e rebuilt with all the goodies and swapped out the 236 for a 213c manual shift from a 93 s-15. I made up some rock rails and swapped the 37's for 39.5's http://i4.photobucket.com/albums/y15...6_770606_n.jpg http://i4.photobucket.com/albums/y15..._2835975_n.jpg |
That is BEAST!!! What transfer case did you have to end up useing?
I used a 231c out of a 93 S-15 , I still need to put another tone ring on the output shaft so it will shift gears in 4lo but I'll get to that later.
One word, COOL!!!
Ok I'm not use to the numbers because I've never had to do anything big to my t-case
Seen most of this on the C.O.R.E. website. Coolness. Best story was trying it out with the welds only tacked and it falling down.
Hahahah ! sometimes I do so really stupid things .
Freaking AWESOME!!! What gears are you running? And another 4.3?
Thanks .
I'm running 4.10's for now ( sucks but .... ) I went with another 4.3 |
