aftermarket gear shiff
Hey fellas! dont get hasty but im in the process of doing the interior in my 1997 chevy blazer and want to know if there is any good gear shift for an automatic transmission?? im wanting to replace the stock gear shift with an aftermarket one but dont know what to get?? can u help me out?
this is the one im looking at
B&M 81120 - B&M Stealth Pro Ratchet Shifters - Application - SummitRacing.com |
That's nice! Now I'm wondering how to take off the shift knob
I don't think this is the correct area for this thread! That being said just to get a better answer for you you will need to be more forthcoming with info about your truck. Is it floor or column shift right now, what motor trans combo, or plans for a motor swap, why do you want a different shifter, what are you hoping to gain from this shifter, what is the intended use of the truck. I just don't see any use in a ratchet shifter in a blazer unless you have a motor swap and intend to drag race it or something. If its just a stock motor and trans honestly I wouldn't touch the shifter at all. If you have a floor shifter you can alway get a nicer shifter from a bravada or something. This is why we need more info please!!
Mine is column shift and I manual shift it in the woods all the time. Helps keeping the engine in the right rpms at times.
| All times are GMT -5. The time now is 02:30 PM. |
