Altoncustomtech's 2001 Jimmy = slow audio build
Alright, glad to start getting this posted up. With work and home taking up a lot of my normally free time this build will likely continue on into next year. Already installed in the Jimmy is the Kenwood KDC-X492 HU and Phoenix Gold RSD 6.5" components running off the HU. The PG's will be getting replaced by a set of Image Dynamics CTX 6.5" components powered by a Sundown SAX-125.2. The sub stage is three Sundown SA-8's powered by a Sundown SAZ-1500. RaamMat is going on the doors and panels and all wiring is Knukonceptz. Got everything on hand, just need to get it installed now. Onto a few pics.
A shot of the 125.2, bought used from Jacob at Sundown Audio. http://i889.photobucket.com/albums/a...226001901a.jpg A few shots of the SAZ-1500 and the SA-8's. http://i889.photobucket.com/albums/a...0324001255.jpg http://i889.photobucket.com/albums/a...324001255a.jpg http://i889.photobucket.com/albums/a...324001255b.jpg Now onto the build. I wanted to get the mid out from behind the door panel when I built the MDF baffle for it. Luckily the way the panel is made makes it very easy to do. Cutting the factory grille out of the panels. http://i889.photobucket.com/albums/a...1011001753.jpg http://i889.photobucket.com/albums/a...1011001757.jpg http://i889.photobucket.com/albums/a...1011001759.jpg http://i889.photobucket.com/albums/a...011001759a.jpg One down, and the implement of destruction that helps make it so easy. http://i889.photobucket.com/albums/a...011001759b.jpg Now onto the driver's side. http://i889.photobucket.com/albums/a...1011001806.jpg http://i889.photobucket.com/albums/a...1011001821.jpg http://i889.photobucket.com/albums/a...1011001823.jpg http://i889.photobucket.com/albums/a...1011001824.jpg And the basic look of the finished product. http://i889.photobucket.com/albums/a...1011001828.jpg http://i889.photobucket.com/albums/a...011001828a.jpg |
Now for a little fab work.
Cut these out to match the factory plastic speaker housings, baffles, holders, thingys. http://i889.photobucket.com/albums/a...1017001343.jpg Getting the tools out and ready, though I forgot the small jig doesn't go up the the circle sizes I need for this, oops. http://i889.photobucket.com/albums/a...1017001417.jpg Getting started on the holes. http://i889.photobucket.com/albums/a...1017001437.jpg Cut this one out for a test fit hole for the Image Dynamics mid. http://i889.photobucket.com/albums/a...1017001458.jpg The greatest thing about using a router to cut the holes is that you can leave enough to make all the required cuts and finish the cuts like I did with my pocket knife, almost paper thin. http://i889.photobucket.com/albums/a...1017001559.jpg Quick shot of the recesses cut into the outer ring for the mids. http://i889.photobucket.com/albums/a...017001559a.jpg Rings are out and showing the fit. http://i889.photobucket.com/albums/a...1017001609.jpg http://i889.photobucket.com/albums/a...1017001611.jpg This is a basic shot of what the baffles will look like when complete. I still have to align the rings with the hole in the door panel before I can attach them to the baffle board and cut the hole in it. http://i889.photobucket.com/albums/a...1017001614.jpg Gluing the rings to get them together http://i889.photobucket.com/albums/a...1017001623.jpg The rings are complete and ready to do the final alignment and finish the baffles. http://i889.photobucket.com/albums/a...1017001625.jpg |
nice
:icon_speaker1: |
I like your style. Cant wait to see it finished.
Me likey!!!!!
hey alton, what battery are you putting in the back? i see c & d but which?
how much is this running you price wise?
Originally Posted by djerock
(Post 371791)
nice
:icon_speaker1:
Originally Posted by Allwaysblazin
(Post 371796)
Originally Posted by wlorton
(Post 371875)
Me likey!!!!!
Originally Posted by MTopper
(Post 384824)
Originally Posted by k5blazer
(Post 385041)
Okay, little update here. A friend on another forum was a real gem and sent me a couple of old Type R components tweeter cups to help out with the install. It seems that the flush mount tweeter cups for the PG RSD tweets are much larger than the Bravox CS60K tweeter's flush mount. Would have had the same problem with the ID's as well. So I got to working on it a little this weekend and was able to verify for certain that the Type R cups should work fine, of course with a little modification. Here's a few pics....
Here's a shot of on of the Type R cups. http://i889.photobucket.com/albums/a...0515011605.jpg Here's a comparison of the cups after removing about 1/16" of material on one, you can see the tooling marks. http://i889.photobucket.com/albums/a...515011605a.jpg And here's a couple of pics of the Bravox tweeter in the tooled cup. Fits like a glove, though I'll be securing them with a little CA glue before installing them in the truck. http://i889.photobucket.com/albums/a...0515011608.jpg http://i889.photobucket.com/albums/a...0515011607.jpg |
looking good Alton. which Bravox set did you get?
| All times are GMT -5. The time now is 10:05 AM. |
