Aluminum + ? = Cut
Quick question to pick the brains of the community. I have a slab of alumin, 3/16" thick and about 3'x3'. I wish to craft a skid plate from it since I am currently running around with just a bumper (no valance/air dam) and want something up front...
My question is this: How the hell do you cut it? i have gone to town on aluminum before with a sawzall, but the heat must have softened up the aluminum too much, because it gummed up the blade and SUCKED to cut. I have also taken a shot at some with a standard air powered cutting wheel. That was a disaster as it ate up wheels faster than steel and was slooOOOooow going.
I do not have a torch, and think that would be a bad call even if i did... so wtf do you cut alluminum with? pnematic snips?? mind bullets? lasers?
help o masters of metal!
BONUS ROUND: i do not plan to slide UP rocks or OVER stumps on aluminum, but standard smashing through brush, road hazards, small animals should be ok if mowed down by 3/16" alum plate right?
Click the picture... I can't convert mm to inches in my head but I think 1.6mm thick aluminum will have you covered.
*EDIT*... I pulled out the unit converter and my "bright" idea... ain't so bright no more. I'm gonna say lube the blade on the sawzall as you go like 96chevblazer said.
Yeah, I would say run some lubricant on the blade. The more aggressive you go with the blade, the cooler it will cut. Go with like a 10-14TPI blade and have someone spray it with WD40 as you cut. It will vibrate like hell, but it will make a good cut. Just support the plate well enough keeping the sawzall down on the part with good pressure and you should be good.
LOL @ the sharks with frickin' lasers!
Ok, i have heard cheap soap, WD40, and tranny fluid (the car kind weirdo!). looks like im gonna need a lube pal, good job for the wife...
I think there is a 10 or 12 tpi blade floating around somewhere... Or i bent it while making a worst fence since 1,200 B.C. and will need to grab a new one. i guess i can C-clap the hell out of it and go to town...
worst case senarion I destroy some expensive material and am left with a ruined sawzall, one less thumb, and a trip to the E.R. Best case senario, I post up my first real fab work and get snickered at by the forum.
Either way, i'll break out a field dressing, safety goggles, and a few brews this weekend (cleared a spot in the garage!) ... hold on to your fingers boys! This weekend is going to end in a) tragedy or b) me FTW!
