Another SAS Build
Old Sep 21, 2020 | 05:24 PM
Jesusp64's Avatar
Jesusp64 is on a distinguished road
Default Another SAS Build
Hey yall so im currently doing a SAS on my 2001 chevy blazer. I haven already swapped strip the hole IFS from the front and removed the rear axle. Im currently working on swapping my new TC. I went from a np236 to a np231c manual selector.
do any of you know what i do with the electrical that goes to the np236 i took out ? I know i only need one speed sensor for the np231. But the np236 has 3. Do i just delete them along with the shift motor ? Thanks in advance
Old Sep 21, 2020 | 06:03 PM
I just left the plugs unplugged. You'll get the Service 4x4 light, but that can be "fixed" with a slight bulb modification.
Old Sep 21, 2020 | 09:11 PM
Jesusp64's Avatar
@Tom A yea or i can just do that. I guess im just over thinking it.. i was trying to keep the
"4x4 service" light happy.
Old Sep 22, 2020 | 09:21 AM
I don't know if there's any way to make it stay off. You might possibly be able to remove the TCCM, then flash the PCM with a tune from a manually shifted truck. I chose the bulb modification route.
Old Sep 22, 2020 | 10:27 AM
Jesusp64's Avatar
@Tom A light bulb method sounds easier hah
Old Sep 22, 2020 | 10:56 AM
That was my thought, too.
Old Nov 14, 2020 | 12:36 PM
Joe Paul's Avatar
Joe Paul is on a distinguished road
Default tc electric shift
would like to shift the TC without computer, I would need a wiring diagram for the module and input signals to bypass or delete. Red and Black at the TC will shift between 2 and 4wd, but not low or high
Old Nov 14, 2020 | 12:51 PM
Jesusp64's Avatar
@Joe Paul so my plan is to to install a center counsel for the manual shifted 4x4 of a older blazer. I believe 98? Can't remember and wire it in. Ill post some pics later.
Jesusp64's Avatar
djjdn
Old Nov 14, 2020 | 06:25 PM
Joe Paul's Avatar
blazer is under a 40 ford pickup with bench seat, not much room, I need to open the door and get out to change my mind
