"dirt devil" build thread
49 Attachment(s)
how do u upload pics from photobucket.
just copy the image code "img" and paste
ok so i decided to do a build thread of my own. i bought a 2000 gmc jimmy on jan 20 for 280 certifed and e-tested. i first gave it a wash and added a bug deflector and rain guards and a set of 8k hids.
https://blazerforum.com/forum/[IMG]h...ps7815c05a.jpg[/IMG] |
its not letting me add pics from photobucket
Copy the image link (bottom of the 4 available) and paste it in your reply.
1 Attachment(s)
ok so i decided to do a build thread. i bought a 2000 gmc jimmy slt 4x4 in jan 2012. i paid 2850 certified and e-tested. first thing i did was clean it up and add bug deflector,rain vents and 8k hids
https://blazerforum.com/forum/attach...ine=1364183491 |
5 Attachment(s)
https://blazerforum.com/forum/attach...ine=1364183934
then i added performance cross drilled rotors and carbon ceramic pads and bled the brake lines https://blazerforum.com/forum/attach...ine=1364183934 then i purchased a set of 31x10.5r15 bf goodrich all terrain tires for 200 bucks https://blazerforum.com/forum/attach...ine=1364183934 then i added a aluminum brush gaurd,4x blazer offroad lights with 100 w bulbs and a uniden cb with whip https://blazerforum.com/forum/attach...ine=1364183934 i then did a full tune up,ngk plugs,sea foam the motor,use sea fom in the gas,maxx performance distributer cap and rotor and perormance wires and blaster coil. then i changed the fuel filter and the 2 02 sensors to ntk. then i changed the engine and transmission mounts to energy suspension poly urithane,then i changed the fluids to kendall synthetic for the front and rear diff fluid,then i changed the u joints on the drive shaft to greasable ones,i also added moog inner and outer tie rods,moog ball joints,moog pitman arm and idler arm,i also upgraded to a jeep universal joint steering shaft to rid of the sloppy steering,i then took my truck to the local tuner shop to have my ecu reprogrammed from hp tunerz. i must say it was the best performance upgrade to buy for 200 bucks.i then also bought a new radiator and switched to the green coolantt,bought a new a/c compressor,new thermostat,new rad clutch fan |
| All times are GMT -5. The time now is 08:22 AM. |
