Disjaukifa's Cheap 1998 Blazer 4x4
1 Attachment(s)
Hey Guys,
I've got a stock 1998 Blazer LS 4.3L V6, 5-Speed and a4x4 with 2-door. Essential I want a mix of a vehicle. I want a vehicle I driver everyday but go off roading with friends here in North Carolina all day long. Here is my current setup and what I have to fix: 1st: I've got to fix my clutch. I think the clutch slave cylinder went bad. 2nd: Get the truck to pass NC inspection. 3rd: Remove crank fan and install electric fan 4th: Strip the rattly interior and carpet, Rino Line, the floor and lower half of the body 5th: Install body life kit, thinking either a 2" or 3" lift 6th: Install bigger tires. I'm current running 235/75R15, I would really like to run 31 inch tires on this Blazer I plan on doing this on a budget and document the entire process. I finally got the Blazer running again today, you have to pump the CRAP out of the clutch but I was finally able to get it to move, here is a picture of it trying to jump it today: https://blazerforum.com/forum/attach...ine=1386561400 I'm hoping to have the truck on the road and legal sometime next week! Thanks Grant |
Sounds like a project, good luck. I've recently thought about a rhino liner interior. My work truck is an F150 and I've always liked the vinyl seats and floorboards.
hello fellow 5 speeder I have 1997 and start right were you are and did everything you have on your list any questions pm me or something
after I did everything you did I just went with a solid axle swap and its my daily driver https://blazerforum.com/forum/builds...le-swap-80180/ |
| All times are GMT -5. The time now is 04:25 PM. |
