-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   DIY Custom roof rack (https://blazerforum.com/forum/builds-48/diy-custom-roof-rack-24483/)
amazinnblazin Oct 30, 2008 02:32 PM
I have a twin size old mattress box ( http://good-times.webshots.com/photo...03510336DSDgbx ) that i realized a while back would probably make a good roof rack. after i tear it down to just the wood, do you think i could add some more support (more wood, maybe metal plumbers tape) and RHINO line (or something similar) the whole frame? I'm wondering if load weight would be a problem, but with the right support should be okay, but also with the lining, would it stand up to XYZ mph wind at freeway speeds? ( i saw a mythbusers or something where they were shooting and blowing up rhino linings, and it looks pretty much bullet proof. any thoughts on all of this? btw i'm all about DIY and keeping my money mine!
bobditts Oct 30, 2008 03:48 PM
RE: DIY Custom roof rack
creative, but ghetto! lol. Its all made out of wood right?
amazinnblazin Oct 30, 2008 04:30 PM
yeah, all wood, the rest im taking off (cardboard, fabric, etc)
brokenfish Oct 30, 2008 06:39 PM
you can buy pre bent pipe and connecters the most you will need is a drill and a hack saw wont cost much (rhino liner aint cheap), it will look way better and you wont have to worry about it falling apart. IMO.
willjones Oct 30, 2008 07:09 PM
Do not use wood. For one thing its going to look absolutly rediculous, and another it will more than likely not hold up for very long. And more importantly its going to look lame.
djdrew010 Oct 30, 2008 08:51 PM
ORIGINAL: brokenfish
Buy that and use that frame as a template. Then rhino line the metal tubes. It may not be cheap but you did it yourself and using that box spring as a template is a good start, half the work is done.
amazinnblazin Oct 30, 2008 10:12 PM
ah yes, that is a good idea to use it as a template, then again, no need to line it if its metal
djdrew010 Oct 30, 2008 11:23 PM
You'll need to do something so it doesn't rust
amazinnblazin Oct 31, 2008 11:20 AM
The prebent pipe and connectors, is that something i can pick up from Lowe's/ Home Depot or what?
Thx
brokenfish Oct 31, 2008 01:44 PM
should. or try electrical supply places and get conduit it's easy to bend galvenized and shouldnt cost too much but you can also get stronger pipe which will last longer for that talk to a welding supply store.
