GMC Jimmy 2.5" Lift 31x10.5 etc
1999 GMC Jimmy Cherry Red Metallic 4x4 Auto 4.3 Vortec, Flowmaster P40 Muffler, (Rough Country 2.5" Suspension Lift) Front Extended Upper control arms w/ball joints, driver/passenger differential drop brackets, torsion bar keys, Rear Lifted shackles, sway-bar relocation brackets, Rough Country N2.0 series shocks, Soldered ABS Sensor Line, Trimmed Fenders, BFG All Terrain T/A 31x10.5", Black Rock Crawler 52s 15x8 4.5BS, 1.5" Wheel Spacers in Rear, Chrome Lugs, Black Grille, 0% Tint Rear 30% Tint Front 20% Tint Banner, Clear Headlights, SilverStar Bulbs, Auto Headlights Disabled, DRL's Disabled, Seat Recliner Shafts/Handles, Black Tow Hooks, SS Bolts in Plates.
http://i46.tinypic.com/2dujvgj.jpg http://i45.tinypic.com/343qft1.jpg http://i45.tinypic.com/30a6d6h.jpg http://i48.tinypic.com/978nrk.jpg http://i49.tinypic.com/33oqg43.jpg http://i50.tinypic.com/2s6vl76.jpg |
Very sexy!!!
(Post 523261)
Very sexy!!!
My ABS Light came on Im assuming its the tires. |
Looking good!!!!!!
Try cleaning the sensors on the hubs and check them over really good they may have gotten dirty or damaged with the lift install.
Alright thanks! I noticed my speed is 5 off at 60 do i need a pcm tune to fix that? I got 2 tunes from pcm4less before one the truck wouldnt start the 2nd it ran like crap. he wasnt sure why and I dont know why my truck wouldnt take the tunes.
Wierd on the tune issues! I've never had one so I'll wait for others to help you out with that. As for the Speedo its of cause of the larger tires. Mine is off too. I think a tune will fix that tho.
Nice!
Thanks guys! Yeah the sensor became unplugged (If the wire by the passenger front wheel is the abs sensor? It barely reaches so Im going to try and reroute or make it longer so it doesn't happen again.
I used black bear performance for my tune. And I love it, they should be able to adjust the speedo for the size of tires you are running as well as adjust for gears, etc. Check out black bear. The tune is 200 if you send them a pcm, or 260 if you keep your pcm.
