KM346's SFA blazer (lots of pics)
Hey everyone, had some time today so i thought it would share my SFA build over here. Some of you may recognize it...
Truck: -2001 Blazer LS 4 door 4x4 72,000 miles Front axle: -High Pinion YJ Dana 30 w/4.10 gears -ORD leaf spring SFA kit -Rancho 44044's spring under axle -Dana Spicer axles w/760X u joints -TJ one piece passenger side axle -F250 rear shocks Steering: -JB4x4 high steer arm -YJ pitman on a ZQ8 box -Moog YJ tie rods -Custom drag link (91-95 ends + 87-90 adjusting sleeve) -WJ front sway bar w/ YJ extended links Rear Axle: -Ford 8.8 w/4.10 gears -Spring over axle -New Ford axles / wheel bearings -SN95 Mustang rear disc brake conversion -Bastard pack w/ 1 ton leafs -K1500 rear shocks w/ custom axle mounts Driveline: -1st gen s10 extended cab rear driveshaft w/ 2-1569 conversion Ujoint -XJ front drive-shaft (needs to be shortened) -1st gen electric shift t case w/ Jeep NP231 yoke -ORD transmission cross member Misc: -TJ Rubicon wheels -pro comp extended brake lines (front) -K1500 Silverado center brake line (rear) -custom modified y-pipe -JTR 2.8 HD motor mounts I'm sure I'm missing some details, just ask if you have any questions. |
6 Attachment(s)
5 Attachment(s)
4 Attachment(s)
Trucks looking sharp Nice work !
looks good, nicely done!
Good looking blazer! Those rims give it a nice look!
Clean
Thanks everyone!
1 Attachment(s)
Bought a Trac-lock carrier off craigslist the other day for the 8.8. Ideally id like to have a locker back there... but this will be way more street friendly, and i got a good deal. I plan on rebuilding it with extra clutches so hopefully its nice and tight. :icon_naughty:
Attachment 33015 |
| All times are GMT -5. The time now is 06:05 AM. |
