-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   Little Mouse - The 1994 - 4.3l TBI engine blueprint and tuning (https://blazerforum.com/forum/builds-48/little-mouse-1994-4-3l-tbi-engine-blueprint-tuning-92047/)
error_401 12-17-2020 04:26 AM
Hi Les,
Good advice. I'll check again for sure.
Nice setup. Pretty much the same that I used. I'll degree the cam a second time before making any modifications. I have taken the measurement twice, then the machine shop owner did it and we ended up at the same spot. I'll take everything apart again and start from scratch before any modification.
I use the CompCams degree wheel and stop. Had to make some more adapters with different metric threads to use on other engines (aluminium block) where the magnetic stand does not fit or hold onto. The long dial gauge comes in handy. I have measured on the lifter itself as I have two old lifters with aluminium insets so they are fixed lifters now. The next time I'll check with the cam follower I have. From there being a "net" measurement I'll go to the 0.050 lift and from there derive the cams placement. It's possible that the method of measurement I use causes the error.
I don't like all that discussion on advertised and such lift and go for net numbers which I can plug into a spreadsheet and derive the curves. As the cams are defined at the 0.050 lift point I may have skewed results because of that. Which would actually be very nice as it will save me a lot of machine work.
The piston stop I have is a nice solid aluminium bar with a stop that has a hard plastic point. Nice in order not to damage the piston. I'll upload a picture the next time I degree the cam again. All in a sturdy box that can be stacked together with a very small valve removal tool I made years ago, some test springs, adjustable rods, pointer and couple adapters for the dial gauge.
Part of the kit I use. I like COMP's sprocketed wheel as it gives you access to the cam's drive components.
https://www.compcams.com/pro-camshaf...inder-cpg.html
We'll probably make an appropriate adapter for European cars where it can come in handy. The large diameter is also nice and very accurate.
LesMyer 12-17-2020 10:35 AM
Sounds good! Possibly something in your method is throwing things off. Going 0.050 on each side of the lobe and determining half way in between as the exact center of lobe should eliminate any method errors as they tend to cancel each other out this way.
Good luck and let us know how the Intake Centerline Method works for you.
Les
error_401 02-17-2021 03:03 AM
Finally got the parts ordered from Summit. Including correct length pushrods. I hope to re-check valve timing this week. With a new timing chain set from the 5.7 I may have adjustable keys now.
Les,
I will re-check both centerlines, intake and exhaust. I have a little doubt that COMP has built in some advance in this street cam but not advertised it. If they have advanced it it may even help the torque curve. At least now I can put it wherever I want it to be.
LesMyer 02-18-2021 12:48 PM
Great! Sounds good!!
