mdehoogh's 98 build
  #131
Old 02-28-2011, 09:55 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
you can hit some mad shopping carts with that
  #132
Old 02-28-2011, 10:57 PM
old skool luvr's Avatar
Originally Posted by mdehoogh
lookin' sick Matt!
while i'm not usually a big fan of the blacked out wheels, your rig pulls it off, in spades! i wouldn't add any caps, looks just right as she stands now.
  #133
Old 02-28-2011, 11:01 PM
Benedict1337's Avatar
The stock chevy caps for these require those lug nut threaded caps as well and I don't really care for those.
I wonder if the cragar kind would work...
lol my spare rim is the same as your rims I'll see if my center caps from my pro comps work
  #134
Old 03-10-2011, 10:03 AM
mdehoogh's Avatar
Just picked up a full-sized spare. Maybe it will motivate me to finally put the swingout carrier on the back :P
No damage, holds air and only $20! Thank you craigslist. Now if only I can find a PA3 wheel to put it on
  #135
Old 03-10-2011, 11:41 AM
too bad you're so far away I'd give my my spare rim. lol its already black
  #136
Old 03-10-2011, 12:43 PM
mdehoogh's Avatar
Yeah I sprayed my spare rim with the tire still on. You can kind of see it underneath the BFG in that pic. The only problem is the spare rim isn't the same as the ones on my truck. The spokes are a little bit different between the 2WD and 4WD steel wheels so I've been trying to find a wheel that actually matches but I guess the stock spare is close enough.
  #137
Old 03-10-2011, 01:32 PM
I didn't think they were that different from the 2wd other than the backspacing... if you do decide to get a rear tire carrier the spare rim you have now will fit nicer on the rack than the 2wd rim. my pro comps stick out a little since the backspacing isn't as much
(stock wheel)
the 2wd will probably stick out about the same as my pro comp
  #138
Old 03-10-2011, 06:29 PM
mdehoogh's Avatar
thanks for the pics, now I'm glad I went ahead with the stock rim instead of holding out to find a matching 2wd rim. I wonder, though, if there's a difference between 2wd and 4wd tire carriers to account for the different wheel specs
Other than the lower backspacing, there's barely any difference between them anyway.
4WD
2WD, they need to be repainted but it looks especially weird in this pic b/c it had just been washed
  #139
Old 03-18-2011, 10:41 PM
mdehoogh's Avatar
I've updated the other thread about tire carriers on 4drs but I figured I'd post in my build as well.
Anyone know a way to turn the white letters black? The black sidewall is in much worse condition so I had them mount white out. I guess it's not that big of a deal but there's very little white/silver on the truck and I've been trying to avoid it as much as possible
  #140
Old 03-18-2011, 11:22 PM
s14sh3r's Avatar
I've seen people use black silicone to hide white letters mounted to the inside. I don't know how well it would look close up though.
Quick Reply: mdehoogh's 98 build
