-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   Mike's Green Bean (https://blazerforum.com/forum/builds-48/mikes-green-bean-63537/)
ohsofly Oct 1, 2011 11:33 AM
That is one nice clean blazer! You should be able to fit the 31s on, if they rub you can just grind off the folds in the bottom edge of the fender where they are rubbing.
Mike98Blazer Oct 1, 2011 11:39 AM
Thanks sofly.
I went out and measured for the 31's they will be VERY close to rubbing at the height she's at right now. So i could probably get away with them with some trimming of the inner fenders, not sure if i'm going to go that route or not yet though. We shall see in time. This is going to be a slow build lol.
Speaking of tires, I've got 2 tires in mind. Anyone have any experience with the Dunlops? I was dead set on the Duratracs but then i noticed they don't have them in the 30" size.
http://www.tirerack.com/tires/tires....VOWL&tab=Sizes
Here's the duratrac's for those who don't know.....
http://www.tirerack.com/tires/tires....TOWL&tab=Sizes
xgiovannix12 Oct 1, 2011 11:59 AM
my dad has the dunlops there older versions but there great kinda rough on pavement but youll never get stuck in mud or snow
depends what you do with the truck He uses it for work and going into construction sites where its all muddy and stuff
if you look in my albums there should be a picture of the s10 pickup with them
Edit: Heres a link
https://blazerforum.com/forum/member...0931-16869.jpg
https://blazerforum.com/forum/member...ls-turbo-4035/
thats when i bought them used for 200 bucks with rims =P
Mike98Blazer Oct 1, 2011 01:32 PM
Ok cool thanks gio.
The truck is my daily driver....but i'm going for an off-road / aggressive look without going too crazy with it. I don't mind a little roughness on the road as long as it's not unsafe. I do off road occasionally although nothing real hardcore as the truck is my dd.
Mike98Blazer Nov 10, 2011 04:25 PM
Little update. Replaced the fuel pump and tank.........
And got new SHOES :)
http://i459.photobucket.com/albums/q...o/c824b1d9.jpg
http://i459.photobucket.com/albums/q...o/f0264b3d.jpg
http://i459.photobucket.com/albums/q...o/ca675488.jpg
http://i459.photobucket.com/albums/q...o/5f7f863c.jpg
http://i459.photobucket.com/albums/q...o/273def77.jpg
96blazer4x4LT Nov 10, 2011 11:34 PM
they got some meat on them
gatorboy44 Nov 11, 2011 08:02 AM
Where is the access point for the rear dif?
Mike98Blazer Nov 11, 2011 12:57 PM
The fill point you mean? It's on the side of the diff. Passenger side just above the fin on the pinion sorta.
It's a square driver, I belive a 3/8 ratchet with a short extension will do it.
gatorboy44 Nov 11, 2011 02:14 PM
Yeah my old truck had a plug so I couldn't find it on the jimmy
xgiovannix12 Nov 11, 2011 02:32 PM
I eat beans there good for you !
