Mini-Motorhome
2 Attachment(s)
Was wondering if any others have used their Blazer in this way. I took the back seat out and put in a good 3/4 size mattress (also called a Hollywood style mattress) because it fits right in between the wheel wells. I had to special order it at the mattress store because they do not normally carry them. Then I made some special wood supports for the mattress in the back seat floor area and some custom shelves for each side of it. My wife and I use this rig for camping trips from Bar Harbor, Maine to Redwoods Forest in California and from the International Peace Garden, on the Canadian border to Saguaro National Park in Arizona. I will keep making updates to this thread showing more features that I use on the Blazer and would like to hear from others who have done likewise.
https://blazerforum.com/forum/attach...ine=1411260411 https://blazerforum.com/forum/attach...ine=1411260411 |
I have seen some guys build a box under the mattress to gain storage space
Down fall is that it puts you closer to the roof of the truck |
I like it.
Simple and effective is the way to go. |
what more would you need? :icon_clapclap:
5 Attachment(s)
The following pictures show how I made wood shelves to support the 3/4 mattress and for storage spaces on each side behind the seats.
https://blazerforum.com/forum/attach...ine=1411509703 The center gray shelf has access doors for the storage space underneath when the mattress is slid back. https://blazerforum.com/forum/attach...ine=1411509703 Back view of storage shelves behind the driver's seat. https://blazerforum.com/forum/attach...ine=1411509703 Front view of same storage shelves. https://blazerforum.com/forum/attach...ine=1411509703 Front view of storage shelves behind passenger seat. https://blazerforum.com/forum/attach...ine=1411509703 The next posting will show other storage innovations I use. |
3 Attachment(s)
I also built a roof rack storage rack that is only 6" deep x 42" wide and 6 feet long that holds a tremendous amount of stuff. I wanted to keep the profile low for a little better gas mileage.
https://blazerforum.com/forum/attach...ine=1411511171 Inside it I can carry a 9' x 9' umbrella tent, tool bags, camp stove, replacement propane tanks, fold-up toilet, as well as space for many other things like replacement batteries, plastic baggies, tow rope, booster cables, extension cords, and souviners. LED light illuminates contents at night. https://blazerforum.com/forum/attach...ine=1411511171 I can access the roof top carrier easily with my modified truck tire steps. Bought two, took the step off the second one and added it to the first one for a 2-step model. It folds easily for storage inside beside the mattress. (Later picture will show where it is stored.) https://blazerforum.com/forum/attach...ine=1411511171 Next posting will be more interior mods. |
3 Attachment(s)
For the next installment: I use Reflectix Insolation to cover the windows for sleeping. I used to use black plastic, but found the Reflectix easier to shape and work with as it is stiffer and can be pressed into the window spaces, eliminating the need for tape or Velcro to hold it in place. Old gun racks make excellent places to store tent poles and walking sticks.
https://blazerforum.com/forum/attach...ine=1411574311 Here it is on the driver's side window. I leave a little extra tab on top that can be inserted out the opening with the window rolled down slightly, then when you roll the window back up it holds it securely in place. https://blazerforum.com/forum/attach...ine=1411574311 For added storage space, I added a Steel Horse brand shelf above the sun visors. I use it for storing binoculars, cameras, etc. It is also a great place to clip my cell phone holder while traveling. I have my altimeter mounted to the left side. You can also see several of my LED lights mounted to the topper. I mounted metal L-brackets to the screws holding the topper to the cab and the LED lights attach with strong magnets as they are trouble lights sold at auto supply stores. Recently I moved the mount for my GPS unit up to the shelf above the sun visors as well. https://blazerforum.com/forum/attach...ine=1411574311 Stayed tuned for my next installment. |
5 Attachment(s)
Up here in the colder climates, people often put in 110 volt heaters to heat up the inside of the vehicle. I remounted one to a stub of 4x4 cut down to fit in one of my cup holders. Next, I added a 110 volt thermostat to an outlet box, so that when it gets cool inside my mini-motor home I can turn up the thermostat and have controlled heat inside. My wife thinks it is a "toasty" idea!
https://blazerforum.com/forum/attach...ine=1411583666 Here is a close-up view of the 110 volt thermostat from the front and the side, mounted in a plastic electrical box with a 110 volt outlet out the back. https://blazerforum.com/forum/attach...ine=1411597882http://abe.midco.net/~barondeau1/Vettes/CIMG0063a.JPG To get 110 volts inside the vehicle, I added an extension cord through the grill. https://blazerforum.com/forum/attach...ine=1411583082 If it is to warm inside, I can plug in my swiveling fan that is also mounted on a piece of 4x4 cut to fit in the console cup holder. This and the heater are carried in the shelves beside the mattress behind the driver's seat. https://blazerforum.com/forum/attach...ine=1411583082 Next installment is under the hood. |
4 Attachment(s)
Modifications under the hood include the following: First, I installed the 12 volt air compressor from my old camper (mounted between the jack and the windshield washer fluid reservoir). When I upgraded my camper to a demand system, I had not use for the air compressor any more, so it got relegated to the Blazer. Second, I installed a DIY toolbox for storing the coiled hose for the air compressor and a few tools that I use often. Third, I installed a 2nd backup battery in the empty space on the driver's side of the radiator. This battery is charged during driving, but isolated by a relay when the ignition is shut off. This battery is wired into the interior for all of the 12 volt accessories I run for the mini-motor home such as the oscillating fan, DVD player, and electronics chargers.
https://blazerforum.com/forum/attach...ine=1411601236 Tool box with coiled air compressor hose. https://blazerforum.com/forum/attach...ine=1411601236 For easier access at the rear, I routed an air hose from the underhood air compressor to the rear bumper with a quick-connector. Now I can use the coiled air hose from the rear tires and for the Air-Lift kit that I installed to level the ride. https://blazerforum.com/forum/attach...ine=1411601236https://blazerforum.com/forum/attach...ine=1411601236 Next installment: boxes on the back |
1 Attachment(s)
my set up mattress out of a popup camper Attachment 31057
