my 2001 Chevy Blazer
Im gonna be making these future changes to my blazer.
Im gonna put 2 inch coils and 2 inch shakles with 31s on it with cragar soft 8 rims. Im gonna get 2 10 or 12 inch sony xplod subs just tell me which is better? Im gonna get a pcm tune Im gonna get halo headlights with 10k Im gonna get 35% window tint |
2 inch coil ? your 2wd?
love the color one of my fav blazer colors I have 2 12's not xplods and couldn't be any better gets all the lows and makes my roof rattle pcm tunes are good haven't got mine yet 10k alittle high I had 6k they were really blue and now I have 4300 I don't know how dark that is but my blazer is black with tints you cant see through |
Thanks and yes 2 inch coil springs to fit the 31s because them and shakles cost less than body lift
ok you can fit 31's stock .... if im not wrong there is no coil springs ..... you have a upper and lower control arm torsion bar and just a shock that's basicly it ..... coils are 2wd if im right don't know much about 2wd .....dude buy shackle or a add-a-leaf and just crank up the torsion alittle maybe buy lift keys for the torsion bar.... I had a stock 2wd s10 which is low fit 30's and my blazer a while ago had 31's with stock height then I cranks up torsion bars and did shackles and then I did rough country and wasn't happy and now I ended up with a solid axle swap
do you have a link to these so called coil springs |
ok so I looked at your pictures and you have 2wd rims so Im guessing your 2wd so you do have coils ...... my only question why lift a 2wd
Because i want to make it look better with lift bigger tires and cragar rims
