-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   My 72's "Chevy" Wagoneer (https://blazerforum.com/forum/builds-48/my-72s-chevy-wagoneer-79159/)
Irocz327 May 9, 2013 08:14 PM
40 Attachment(s)
So as some of you know I traded the Bravada for a ... Jeep.. BUT... Its really chevy undercover.. 84 K5 Drive train. (6.2 Deisel, 700r4, NP208, Dana 44's on 35's).
Current to do list...
B
uilding a new harness for engine.
Building a new harness & replacing the stock guages for functioning ones & adding acouple.
Building a new harness for the taillights. (Right now only the blinkers & headlights work)
Finishing the linkages for the transfercase.
Finishing the exhaust.
Re-doing the brakelines down by the OP.
cleaning up & re-doing some of the interior.
Minor body patching & Paint.
& That's all before I really get in to modding it.. haha
well that said now comes the picture overload.
https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498https://blazerforum.com/forum/attach...ine=1368148498
KM346 May 9, 2013 08:24 PM
Looks like it should be a fun project... definitely unique with the old diesel under the hood.
fix that bent drag link too!
Irocz327 May 9, 2013 08:38 PM
Not gunna lie I never even noticed that until you said something.. I'm new to front solid axle but learning. & I'm hoping to Build something big & Learn awhole lot more.
rexmburns May 9, 2013 08:52 PM
This will be fun to watch! Now hurry up no sleep tonight just get to work!!!
KM346 May 9, 2013 09:10 PM
Solid axle stuff is easy... and luckily those waggys have kind of a cult following so there is a great after market for them. check out here if you havent already International Full Size Jeep Association - Powered by vBulletin
also..
Did the PO tell you what they did for a lift? Looks like a SOA conversion in front with the stock springs... and maybe blocks / shackle flip in the rear?
If it has any bump steer it looks like it could use a drop pitman if it doesnt have one already
Irocz327 May 9, 2013 09:23 PM
SOA front w/ rear waggy leafs. Blocks on the rear. I'm not a fan of the blocks but for now they'll have to do until I can afford new lift leaf packs.
As far as the suspension up front goes. its on the back burner.
Right now I wonna get my harnesses all figured out & R&R where needed to clean up the chaos. after that R&R seal/leaks on drivetrain w/ all new fluids in everything.
Then interior/exterior. THEN... suspension fixes and upgrades.. lol
& REX- Man I need to get the 5.4 pulled out of an expedtion this wkend that's been sitting in my garage since feb. so I can have room to get the jeep in while I wait for them to get the parts for the expedition. lol..
Irocz327 May 12, 2013 05:44 PM
So that first project is to tackle the engine harness. Does anyone know where I can find a diagram of the eng harness or at least of injector pump?
rexazz2 May 12, 2013 06:29 PM
not much different than most jeeps, a pile of bastard parts
I was always a little shocked when somebody needed a part and it would the same one used on a GM
That deisel should be able to pull you just about anywhere you what to go
Had a couple company supplied shop trucks with the 6.2 and other than being a bit of a PIA in cold weather they had lots of pep
Irocz327 May 21, 2013 09:31 PM
5 Attachment(s)
So haven't gotten a ton done yet, but did manage to get the return line on the heatercore ran & coolant in it. I also got about 90% of my e fan & coolant tank installed. hopefully will be able to finish the mounts & the little bit of wiring this week.
FYI the zip ties were just there temporary until I had time to finish the mount.
https://blazerforum.com/forum/attach...ine=1369189906
https://blazerforum.com/forum/attach...ine=1369189906https://blazerforum.com/forum/attach...ine=1369189906https://blazerforum.com/forum/attach...ine=1369189906https://blazerforum.com/forum/attach...ine=1369189906
Irocz327 May 22, 2013 09:26 PM
1 Attachment(s)
SO this is wiring Diagram for my E fan. right now I'm running a dual speed single blade thats about 16ins I had for the bravada but decided to put in the jeep since it needed one for right now. so right now I only have the high hooked up because the low speed is burnt out so I'm gunna order a new motor or add another fan.
until then this is how I wonna wire it up so could you guys spot check me & let me know if it's good. & note the breaker is meant to be distribution block on the fire wall & the relay first off the Ign is goin to be my ign source for any other relays in the eng. compartment.https://blazerforum.com/forum/attach...ine=1369276002
