my new "dumped" 98
3 Attachment(s)
hi, im new to the forum. i have had my jimmy for about 3 days now (traded my 94 honda accord for it.) and have a couple questions pertaining to my "build"
any help would be greatly apreciated. 1. I am used to japenese cars and the way they work. and how to mod the fuel supply and ecu to compensate for boost and engine upgrades. My question is, is there a tuneable ecu out there for these with out going stand alone like megasquirt or haltech? 2. i pretty much have decided to go for forced induction for the 4.3 over the v8 swap. would you recommend either a turbo system or procharger? 3. rear end options... mainly looking for any posi options there are out there. dont want a one wheel wonder. it is a 2wd auto and i do plan on racing it at the local 1/8th mile track next summer. also ive been reading about stock 1/8th mile times and was wondering if anyone could shed some light on it. getting mixed answers im guessing it should be around a 10sec 1/8th just based on my CAI honda pulled 10.5s also this truck is dumped to the ground. |
Google Wynjammer... :)
thank you, well that helped on one thing.... but not the others
love it, i wanna do this with my k5.
Now thats the way a blazer is suppose to look. How much has it been lowered?
1: no sure...
2: turbo, more performance options. v8:cheaper, more power, more work though 3: ford 8.8 from an explorer. wagoneer D44, scout d44 |
thanks guys. sorry its taken so long been pretty busy. anyways.
its a 3.5 inch drop all around and...does the explorer rear end just bolt up and would effect the height the truck? also a new problem has come up. it only happens when there is two people in the truck but if a take a left turn and kinda get on it there is like a metallic noise coming from the rear end. not sure if wheel bearing or what.... any info would help once again thank you for your responses |
:icon_banana:
I have an 01 explorer 8.8 in mine and you will need a new pinion flange to bolt the driveshaft up.
Weiland(sp?) supercharger is the way I want to go. Straight up bolt on. bout $2200 Your noise is probably a worn axle shaft bearing or worn axle shaft creating noise IN the bearing. Just fixed both problems on a customers blazer. Get it before It gets any worse and you wont need a shaft. $$$ |
