My small 96 Blazer build
#521
awesome on the shift
and even better on not having to unbolt any of that. everything is coming up milhouse
Everything's Coming Up Milhouse!
#522
The shift controller is an electronic shift kit it has two stages of firmness on the shifts. I didn't have to do anything with the steering shaft it just extended itself as I jacked. I do have a bit of binding in the steering now but you should be fine since your going back to stock height.
#523
Yeah I actually plan to do that! I just need to buy or borrow a dremel to make the job a little easier
#524
Well I got my DR44G alt from FedEx today so I figured I'd go ahead and throw it on
Bought it off a member on s10forum for $50. Not bad I don't think since I didn't have to search the yard for it or anything.
DR on the left
You can kinda see where my other alt looks burnt I dunno what that's all about but it could have something to do with why it sucked so bad lol
Went to Advance and picked up a little longer belt.
All is good to go! Now when I come to a stop my volts stay right at 14 and don't drop to 9-10. I can have the AC on high, high beams on, and the efans on hi and it still stays at 14 volts. I should have done this a long time ago!
Bought it off a member on s10forum for $50. Not bad I don't think since I didn't have to search the yard for it or anything.DR on the left
#525
holy smoke that alt. made that big of a differance.... so Rex your showing 14volts no matter what gets turned on...
#526
Yeah I was running high beams, ac on high, both Efans on hi, my wimpy radio was on, and I had a buddy put it in gear and hold the brake and still read 14v
#527
I am doing mine, probably this weekend. I have to convert it to a 4pin, but I will write that up too. When my e-fans turn on high I drop to about 12v, I also have the intrepid fans. I also got at smaller alternator pulley.
#528
Where'd you get your pulley from? I was thinking about doing that as well.
#529
What was the part number for the belt you got?
#530
It is a "Drive Rite" 970K6. I don't like it and I am going to use it to cross reference and get a gatorback but just haven't had the time yet
I also just finished my Corvette servo install. I will do a write up tomorrow when I have more time to do it right!
